Old 10-07-2006, 11:20 PM   #1
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
Rear Disk Conversion??
I'm wanting to do a disk brake convertion on the rear. I've done a search but can not find any info on it. I though at one time there was a guy on here selling the brackets only.
Grande Rojo is offline   Reply With Quote
Old 10-07-2006, 11:34 PM   #2
pcmcobra
pcmcobra's Avatar
Re: Rear Disk Convertion??
http://www.stainlesssteelbrakes.com/...500_(2WD)/1986
I know there is another, I was lloking at it earlier tonight, another comapny, can't seem to find it
here is another...
http://www.blackbirdscustomtrucks.com/index7.html
pcmcobra is offline   Reply With Quote
Old 10-07-2006, 11:39 PM   #3
Grande Rojo
paper or plastic?
There are a few companys out there that make complete kits but I'm not going to spend $800+
There was a guy selling just the brackets and I think you used caddy callipers and chevy caprice rotors. Alot cheaper!!
....never seen that blackbird stuff before...thanks for the link!!!
Old 10-08-2006, 01:55 PM   #4
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Rear Disk Conversion??
I think swervin bought some bracket templates off of someone on ebay. His write-up including the templates are here, http://73-87.com/7387garage/chassis_...n/reardisc.htm. He's using the Cadillac setup as well.
A couple of years ago, I talked to the owner running TSM (http://www.tsmmfg.com) and asked him about the 73-87 rear disc brake kit. IIRC, he told me that they make the brackets, but use the rotors from 88+ trucks by redrilling them for the 5 on 5 pattern. They use calipers and pads from the cadillac. I asked him about having to upgrade the stock master cylinder to a disc-disc master cylinder as some of the other brake companies recommend. He said that it is really not necessary. He said, at the time, they had a contract with a large delivery company and had installed the brake kits on the company's delivery trucks/vans. He said the company never had problems with their kit. (He said the company was in the process of upgrading their fleet with the newer vehicles that come stock with rear disc brakes, so his conversion for this company was no longer needed.)
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 10-08-2006, 09:30 PM   #5
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
I'll tell you that on a 4x4 1/2 ton, changing the master cylinder and probably the proportioning valve is absolutely necessary. I used the SSBC kit and it was never right. I never did change the master cylinder so that might have made it better, but I switched back to drums to get decent brakes again.
Here's a writeup about what NOT to buy:
http://www.gmtrucks.org/component/op...isc_brake_kits
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
