Old 10-10-2006, 09:56 PM   #1
HotRod73
HotRod73's Avatar
Bed Question, Please Help!!!
I have a 73 truck and im using a bed from an 82... the 82 has fuel doors mine just has the gas cap on the outside of the bed, will i need anything extra to do the swap? will my filler neck still fit the new bed or what???
HotRod73 is offline   Reply With Quote
Old 10-10-2006, 10:50 PM   #2
lurch115
lurch115's Avatar
Re: Bed Question, Please Help!!!
just change the fill tubes from the '82 over to your '73 because they will be a little different...but that is all you should have to do
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 10-11-2006, 08:02 AM   #3
beaterC10
You need to look at the diameter of the 82 filler neck and the size of the opening on the 73 tank, I am pretty sure you will find the 73 tank is smaller. I had a tank from a 77 and the opening on it was smaller than the filler neck on my 86.
beaterC10 is offline   Reply With Quote
Old 10-11-2006, 08:39 AM   #4
HotRod73
HotRod73's Avatar
i got a 3/4 ton the 82 bed is off a 1/2 ton and they are both dual tanks, does this matter???
Old 10-11-2006, 08:49 AM   #5
Jonboy
Slots go on anything!
doesn't matter, but the neck size is different. I made an adapter from the plumbing aisle at Home Depot to get mine to work.
Jonboy is offline   Reply With Quote
Old 10-11-2006, 09:27 AM   #6
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
My 80 model had the original filler tubes punched out for the old leaded gas nozzles, so I used the 87 filler tubes that attach to the bed cut the rubber hoses to attach to the lower part of the 80 filler tubes on the tanks.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 10-11-2006, 09:35 AM   #7
bodydropped
i did a duel tank bed on my 79 but i have one tank and i changed over the tubes and it turned to be a btch to fill up
bodydropped is offline   Reply With Quote
Old 10-11-2006, 01:25 PM   #8
mhicks
mhicks's Avatar
Not to hijack thread but if you add a second tank, can you just tie both returns and supply lines together and the gas be drawn from both tanks equally?
If the pump succked at a different rate from one tank than the other, would the level equal out when not running?
I was wanting to add a second tank to mine but it seems like a big hassel with the switch and wiring.
mhicks is offline   Reply With Quote
Old 10-11-2006, 01:48 PM   #9
HotRod73
HotRod73's Avatar
atualy mine just has a valve on the floor by the door, has middle left and right and i think middle means it takes from both... no wiring.. except the hoses
