body panel gaps
In the daunting task of fitting and aligning new floor pans and panels I have noticed that I have gaps in the metal where I cut and fit the new panels, large enough that I cannot weld a bead there. The gaps arent much more than 1/16 of an inch wide, what should one do to fill the gap, caulking ??
Re: body panel gaps
You can close up a 1/16th of an inch with a welder if you take your time and work back and forth and side to side.
Re: body panel gaps
What if not??
'69 Step
Re: body panel gaps
Do you have spare sheet metal you can use to bridge the gap and weld in on both sides??
Re: body panel gaps
duct tape
Re: body panel gaps
Briging the gap with sheetmetal can work. It is wicked hard to be precise with cutting and fitting.
![]() Join Date: Nov 2004
Re: body panel gaps
That can be somewhat cured by cutting the panel slightly large, test fit, grind down areas that are too big, test fit, grind, test fit, grind. It's a pain in the ass but it worked for me. My very first welding job was on this a few months ago:
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: body panel gaps
Damn that looks sweet.
Re: body panel gaps
After the weld/grinding, what did you use? Metal prep, rust encapsulator, body filler, then prime and paint?
Re: body panel gaps
Basically, yes. I love rust encapsulator. Don't use it on a hot day though, that crap dries FAST! Thanks for the props. There was a long time between pic one and pic two
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-11-2006 at 03:47 PM. |
Re: body panel gaps
hey that looks great, you took the spare tire mount out and placed a tank back there, not a bad idea. I used some rust encapsulator from Car Quest, I want to get some from Eastwood, but cant wait too long, I guess it's all the same. I have some spots to sandblast, lots of work. Looks good tho.
Re: body panel gaps
BTW is that a piece of tailpipe used for a fuel filler?
Re: body panel gaps
No, not the main piece that you see. It is stock '96 Silverado fuel filler neck. The diamater on the silverado filler neck was much larger than the blazer tank filler neck, so I did use some muffler pipe from a parts store to make up the difference in the filler neck size using 2 different sized rubber fuel hose. Hope that makes sense??? There is a lot of detail and pics in my "build thread" in my signature.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-11-2006 at 04:49 PM. |
![]() Join Date: May 2006
Re: body panel gaps
Sometimes I have placed a piece of copper behind the gap, sorta supports the molten metal so it doesn't drop out. Worked for me!!
#15 |
Re: body panel gaps
Turn your wire speed up and amperage down. Not too much. Practise on scap first. With short bursts you can build up enough metal to weld the two together. Do small sections at a time. You want to hear it "POP" as opposed to "sizzle".
#16 |
Re: body panel gaps
Now if you are using a wire feed welder than a 1/16" gap is just about right. When using the wire feed you want a gap in your metal the same thickness as the metal that you are welding. Practice, Practice and then more .....
Kevin LFD Inc. |
#17 |
Re: body panel gaps
Use a carbon block or a piece of brass on the back side and you'll be able to fill the gap. We use them at work when welding odd angles that or band saw won't cut.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
