Old 10-19-2002, 06:21 PM   #1
chevjayfsd
Project 7dos
chevjayfsd's Avatar
!!!!!!!!VERY IMPORTANT!!!!!!!
What is the most likely cause of less lift on one intake valve then all the rest. There is only one that is not lifting enough. It is the same cylinder that the rocker arm stud has pulled up before. Is it okay to drive???
ANy ideas
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 10-19-2002, 06:46 PM   #2
crazy longhorn
Fabricate till you "puke"
It sounds like a "rolled" Lobe on the cam. You might check to see that the stud hasnt pulled again, or possibly a bent pushrod. Good luck.....Longhorn
crazy longhorn is offline   Reply With Quote
Old 10-20-2002, 12:09 AM   #3
chevjayfsd
Project 7dos
chevjayfsd's Avatar
ttt
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 10-20-2002, 12:17 AM   #4
bigjimzlll
bigjimzlll's Avatar
I think all the questions were answered here http://67-72chevytrucks.com/vboard/s...threadid=27447
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-21-2002, 12:04 PM   #5
chevjayfsd
Project 7dos
chevjayfsd's Avatar
ttt
Anyone???
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 10-22-2002, 02:01 PM   #6
JimKshortstep4x4
Smile
It sounds like the cam lobe for that lifter is worn out. Unless the rocker is really loose, then the cam is worn. The engine will run for a long time with the lobe worn out. Afterwhile, the lobe will be worn round and the valve will not open. The engine will miss on that cylinder so you will lose power.
Jim
Old 10-23-2002, 12:09 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: !!!!!!!!VERY IMPORTANT!!!!!!!
I'll bet you it is gettng pulled up agian.
I would limit the driving to a minimum...like, moving it to cut the grass.
If it is the stud getting pulled out, things can break and get metal chips in the oil.
If it is a cam going flat, then you DO have metal shavings in the oil.
