Old 10-13-2006, 12:17 AM   #1
jmking9
jmking9's Avatar
paint questions
2 Questions. 1. Whats the right way to prime over the e-coat that comes on new parts (in my case bedsides). do I just need to go over it with a fine grit? If so how fine? 2. Is there somewhere online that shows the all of th factory paint codes for these trucks? thanks
jmking9 is offline   Reply With Quote
Old 10-13-2006, 01:08 AM   #2
CMars45000
CMars45000's Avatar
Re: paint questions
You don't NEED to prime over e-coat unless you want to do it to use a surfacer to spray on and then knock back down...
You can directly top coat over e-coat if you sand with 600 grit. if you want to use a surfacer I go over it with 320 just to get some bite on the new panel..
or you can sand with 400 and seal it...
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 10-13-2006, 05:22 AM   #3
JimKshortstep4x4
Re: paint questions
Here is a link for paint codes.
http://autocolorlibrary.com/cgi-bin/...truck-pg01.jpg
Jim
Old 10-13-2006, 02:37 PM   #4
Greaser
Greaser's Avatar
Re: paint questions
Cmars Is Right. Also Use A Grey Scotch Brite And Go Straight To Topcoat, Or Red And Seal Then Color. I Also Use Something Called Final Sand, It's Kind Of Like Agressive Toothpaste, Use It With A Scotch Brite And It Works Really Well. Key With It, Make Sure You Clean Up Really Well. Some Epoxy Sealers Can Go Straight To E-coat With Out Scuffing At All On Non-exposed Surfaces I.e. Under Hood, Of Inside Fenders. I Dont Trust It Enough To Do It, Just Because For The 15 Mins It Takes To Scuff The Backside, It's Cheap Insurance. Plus Getting A Mechanical, And Chemical Bond Is Always Better.
Greaser is offline   Reply With Quote
