Old 10-09-2006, 04:11 AM   #1
Mcgwirejh
Timing ?
Can anyone tell me the timing on a 1992 chevy 350 tbi i was told it is
0*degress at top dead center but just wanna make for sure.
Mcgwirejh is offline   Reply With Quote
Old 10-13-2006, 12:58 PM   #2
68speedalert
Semi-Senior Member
68speedalert's Avatar
Re: Timing ?
That's correct, with the 'check timing' connector disconnected.
Advance it 2-4 degrees. It jumps off the line better and gets a little better mileage.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 10-14-2006, 06:14 AM   #3
Kevin45
Kevin45's Avatar
Re: Timing ?
Disconnect the wire at the firewall behind the electrical cover (passenger side brown & black wire) and set the base timing at zero. Then as 68 stated advance it 2-4 degrees, tighten down your distributor, then reconnect the wire.
Kevin
'93 Silverado Reg. Cab Shortbox
.060 over 350 Quick and fun!!!
Kevin45 is offline   Reply With Quote
