Old 10-11-2006, 06:03 PM   #1
wareagle_1997
Power Brakes Conversion Help
I am restoring a 70 SWB and wanted to convert my manual brakes to power brakes. There are four mounting studs coming out of the firewall that are 2 1/2 inches apart from center to center. My manual master cylinder is only using the bottom two studs, and there is a hole in the firewall centered exactly between these bottom two studs. The problem that I have is that every power booster that I've come across from Napa to Autozone to LMC has studs coming out of the power booster that are 3 1/2 inches, center to center, and the pushrod is directly centered in the four bolt pattern, not centered with the bottom two bolts. But I have every reason to believe that I have a completely stock setup. Can anyone tell me what I'm missing here?
wareagle_1997 is offline   Reply With Quote
Old 10-11-2006, 06:09 PM   #2
70GMCer
70GMCer's Avatar
Re: Power Brakes Conversion Help
You need the mounting brackets and rod that mount to those studs that are on the booster. Then it will bolt up to the firewall.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-11-2006, 06:14 PM   #3
wareagle_1997
Where would I find that?
So would all 67-72's with stock power brakes require the mounting brakets and rod, or is this strictly a conversion issue?
Thanks for the help!
Old 10-11-2006, 07:42 PM   #4
truckdude239
truckdude239's Avatar
check the parts borad or surcibe for 25 buxs and post a wtb
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 10-11-2006, 07:47 PM   #5
centsless
sufficiently talented fool
centsless's Avatar
All of the 67-72 trucks with power brakes have an adapter/bellcrank assy the bolts to the firewall, then the booster bolts to the adapter.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 10-11-2006, 07:53 PM   #6
mbgmike
heres ours
stainless are 28.00
plated $15.00
You will also need a disc/drum prop valve
mbgmike is offline   Reply With Quote
Old 10-11-2006, 07:54 PM   #7
John @ BROTHERS
John @ BROTHERS's Avatar
Here is a pic of the bracket you need.
1967 Chevy Short/Fleet
1969 Chevy Short/Step
2004.5 Dodge 2500 4x4 Cummins 6spd
John @ BROTHERS is offline   Reply With Quote
Old 10-11-2006, 09:02 PM   #8
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Are there any vendors that sell the original style brackets, or the rod that connects to the brake pedal?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-13-2006, 01:15 AM   #9
Bob B.
Careful! '67-'70 trucks with 4 wheel drums use Bendix boosters, '71-'72 trucks with front disc brakes use Delco boosters. The Bendix booster uses different brackets and linkage than the Delco booster does.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 10-13-2006, 09:05 AM   #10
BowTieOgre
Originally Posted by mbgmike View Post
heres ours
stainless are 28.00
plated $15.00
Are you going to be at the Moultrie, GA swap meet by chance?
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 10-13-2006, 06:16 PM   #11
mbgmike
No but the Alex from outr Va location is going to one around Richmond Va this weekend.
Old 10-13-2006, 08:48 PM   #12
High Speed low Drag
High Speed low Drag's Avatar
Where around Richmond? Any idea?
High Speed low Drag is offline   Reply With Quote
Old 10-13-2006, 11:28 PM   #13
dougs69c10
dougs69c10's Avatar
I ran into the problem of using the 69 booster with the bracket from a 71 and it was a simple fix, I just attached the booster to the firewall loosely, then attached the booster to the bracket then tightend them down, it worked like a charm, and i cant tell a problem at all when steppin on the whoa peddle.
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end
dougs69c10 is offline   Reply With Quote
Old 10-14-2006, 08:22 AM   #14
mbgmike
He told me but I forgot. I know its in Midlothian. I tried to call him but you can call him at 800-398-0537 and talk to ALex. Or call 804-937-3729. Its a small meet nothing big.
Its off Hwy 360 west of Richmond at a place called "Tractor Supply Company"
