White Haze on Windshield
Around the edges of my front windshield there is a white haze that extends from the edges to an inch or two inward. Is this just due to age? I don't think it is anything I can clean off but it is annoying and looks bad. I'm not sure, but I think it has gotten worse the last couple of years.
1972 C-10 LWB, 400/350, 2WD 1972 C-20 Custom Camper, 350/350, 4WD (Converted) |
It's delaminating. The layers of plastic and glass are separating. Time to start looking for a new windshield, since it will only get worse over time.
------------------------------------------------ I say it's only money, my wife says it's only a truck.... '71 C10 Deluxe, factory ac, ps, pb, should be done by 2102 Longmont, CO husker95@hotmail.com |
This topic has come up before on this board, and many many guys have the some problems with their windshields. Including myself with my 72 GMC. colohusker is correct about the delaminating.
Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
and might want to check out this thread before replacing
![]() http://64.246.42.114/vboard/showthre...threadid=27327
Think this is correct. -
The back and side windows are plate glass. The front windshield is the safety stuff. It is in layers. With age, moisture gets in between the layers. That's the white stuff you see. Looks kinda like dried milk or primer over-spray, right? My humble advice would be to get a new windshield, new rubber boot, and hire some pros to install it. That's after you make sure the lip and area between the windshield and drip rail are solid with no rust. A new windshield is pretty cool. Makes a big difference in how you see the world. ![]() |
I forgot something. -
Make sure to tell the dealer that you get your windshield from whether or not you have AC. Trucks with AC will have a greenish tint to the windows. |
I got a New Windshield NO White
I bot a new WS at CARlisle Fall show for my c-10 '69 Rush never sleeps ... only $99 wo hoooooooooo
door and back glass are normally tempered saftey glass
front glass is laminated safety glass, alll glass since early 60;s or so is safety glass, although i have had some '67-70 with laminated safety back cab glasses, same as front glass, and other were normal tempered safety glass pane glass is actually flaot glass, the stuff in most all house an door windows. terminology differs, heh good luck |
My other Love
nothing like getting a new windshield, then getting a frigin chip in the thing a week later argh! (happened to me twice)
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
Used to have a truck
I put a windshield in today in my 68. Took my brother and I about an hour and a half. Started on the bottom and worked our way around with the rope and a bunch of dish detergent . Not too much pressure. Worked fine although the new rubber is slightly smaller than the old and I'll have to do a little touch up painting.
Ive never done one before but unless its just something I absolutely cannot do by myself ...like new exhaust, I WON'T let anyone else work on my truck.
No truck :-( |
Windshields---lots of talk lately--had a new one installed in my truck 4 years ago---two tubes of windshield sealer later and it still leaks!!
Ever wonder why the dash on our trucks have two small holes in the corners ???? Anyway, if you buy a new windshield yourself, you may find it difficult to find a shop to install it and guarantee the job. You may also find that you need a new gasket once you get into the process. Many of the replacements widshields are made in Mexico and are slightely smaller in width/heighth but also in thickness. Some of the seals are too big and or too hard even after sitting in the sun for hours. Have heard of some shops installing new glass for as little as $110. Most shops charge around $300. because they know insurance will pay. If you go into a shop, plead insanity, explain you don't have glass insurance and look PITIFUL, they may cut you a break and give you a deal. Their actualy cost for a new windshield from the Mexico connection is around $50. After having gone thru the mess of trying it myself twice, I got glass coverage from my insurance company. Of course that doesn't help with my project trucks~~~~~~Good luck----Huck ![]() |
Thanks everybody for the great advice. I will probably shop around awhile before I get it replaced or maybe decide to do it myself. I also want to put in a slider on the back windo at the same time and I want to make sure I get the tints correct.
Whats this about the AC trucks having a green tint? Has anyone else heard of this before? Tinted windows was an option on these trucks but I have never heard of or seen a different windsheild in AC trucks.
Fabricate till you "puke"
There are 3 different sheilds, a clear, a tinted (green), & a tint/shade. The top portion on the tint /shade is a dark blue.....
#15 |
I'm not a "know it all" on this stuff, and am eager to learn, but -
If the truck was equiped with factory AC, there was some kind of tint on the glass. Mine was green. crazy longhorn, could you "clear this up" for me (us)? No pun intended. ![]() Thanks Paul |
#16 |
Yes , the factory air trucks did have green tinted glass. the door & rear glass were also green tint. the more base models had clear glass. I cant run option codes tho, as i havent played with that.....i bet Longhorn mail could help there ........crazy AL
#17 |
Strange, isn't it? The non AC trucks that needed it most weren't equipped with tinted glass. ???
#18 |
Mine is factory air. No tint in the glass
No truck :-( |
#19 |
I had to walk out to the garage for this 1.... on my 69 longhorn, tinted glass is listed as an option (B85). The air cond is also listed as another option(J79). I had always thought that the air & tinted glass went together......but evidently not! probably more often than not, the 2 options were put together,as pretty much what i have seen in parting trucks is that the air trucks had the tinted glass. maybe somebody else can shed some light on the subject? ......crazy AL
#20 |
I have seen and have a cab with AC and no tinted glass. And have tinted glass on a non AC cab.
The tint option doesnt seem too common, or maybe I just dont pay that much attention and its not that easy to notice. |
#21 |
its all about the +6 inches
Never seen them listed together. you get A/C, you get a big radiater...that is the only thing I remember seeing. (I don't have my books here)
I have had 3 trucks, no tint on any glass, and one had A/C. |
#22 |
FS new in the box Windsheild >>
bot at the calise show for rust '69 just bot a AZ 71 so NO WS needed as the AZ has a new one intall ... so anybody need one ? i paid $99 lockated in W NY state next to the canal here ...
hughnews1@aol.com thanks |
#23 | |
December 21, 2012
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
