10-20-2002, 11:01 PM | #1 |
Slowly getting CRSS...
funny electrical problem
ever since my father and installed eletric fans, whenever i go to turn the truck off i can turn it off take the key and be ou tthe door before it will kill the motor. If i un hook the fans it shuts off immediately?
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
10-20-2002, 11:11 PM | #2 |
its all about the +6 inches
The fans are turning after the power is shut off, and they produce enough of a charge to fire the coil. THey act as a small generater.
You need some kind of a diode (think of it as a one way check valve for electricity) that will stop the problem. It is a common thing when installing electric fans. |
10-21-2002, 12:59 AM | #3 |
My other Love
ya what longhornmail said, Go to radioshack and ask them for a big mofo of a diode one that can handle a few amps of juice
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
10-21-2002, 07:25 AM | #4 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
IF you run relays with your fan you wouldn't have that problem.As soon as the key is turned off the cicuit to the fan is interupted so it doesn't feed back into the system.
you can see the ones I used in the bottom left corner of the fan shroud,One for each fan.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 10-21-2002 at 07:31 AM. |
10-21-2002, 09:43 AM | #5 |
English Chevy Owner
Definitely make sure your fan is wired through a relay. I have a single fan on my truck fitted by the previous owner and it wasn't wired via a relay. It was switched by an illuminated switch on the dash which would light up even when the fan was off as the fan windmilling in the ram air as you moved generated enough power to light the bulb. I also found when stuck in traffic one hot day that the connections at the back of the switch were too hot to touch, so could easily have caused a fire. Fitted a relay and a new fused supply from the battery and all is now fine. For the sake of a couple of dollars you could lose your truck to an electrical fire, sort it out now!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
10-21-2002, 09:53 PM | #6 |
A quick fix is to change your power source. Sounds like you got it wired through the ignition.
The more I learn about women, the more I love my truck. |
10-23-2002, 02:00 PM | #7 |
I run my fans direct from the battery with two 30 amp ciruit breakers(one for each fan).
On startup the fans can requiere a good deal of amps to start turning(depending on fan of course).The circuit breakers are self resetting so there is no need to change any fuses. Wiring high amp peripherals such as electric fans without relays and fuses or breakers is not recommended.A run-of-the-mill toggle switch is just not designed to handle the full amp draw of an electric fan.Use that toggle switch to trigger the relay and let the relay handle the amp draw of the fans.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
