Brake advice
I have been reading the posts on drum to disc conversions and am not sure which way to go. I just bought a 70 cst. Why not just put 72 stuff on it? I don't mind going to 5 lug. I guess I would change the rear axles also. If I did would it just be the spindals, calipers, rotors, MC and propor valve. I assume the control arms are the same. Any advice appreciated
Re: Brake advice
72 fits well but replacement parts are more expensive. The reason to use 73-up stuff is because of the price of parts plus if you use the control arms you will have rubber arm bushing slightly better ride.
Re: Brake advice
Does the 70 not have rubber bushings in the control arms? And what are the pros and cons of 5 lug or 6 lug?
Out of the carpool lane.
Re: Brake advice
I recommend the 73+ due to the rubber bushings and cheaper parts that are easier to work with. It used to be that 5 lug was recommended due to the wider variety of wheel styles out there, but not so much anymore-alot more variety in 6 lug nowdays.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
