Old 10-18-2006, 03:53 PM   #1
burnitdown612
6" lift rear blocks
Hi I was wondering if anyone knew the specs for 6" rear block for a lift... i am having a friend make them in a machine shop and i need to give him sizes .. if anyone has idea's please let me no .. thanks nick
burnitdown612 is offline   Reply With Quote
Old 10-18-2006, 06:16 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: 6" lift rear blocks
I wouldn't recommend running a rear block that is 6" tall on any truck. I would wait and do it the safe way.
You can do a shackle flip and a 2" block or extended shackles
http://coloradok5.com/shackleflip.shtml
http://www.offroaddesign.com/catalog/shacklekit.htm
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-18-2006, 06:38 PM   #3
Prerunner1982
Prerunner1982's Avatar
Pick up the newest issue of Fourwheeler and look at this truck...and see what unsafe is..
http://www.fourwheeler.com/2006toptr..._terry_gilpin/
Granted the blocks look to have a small loop for the U bolts to go through, but the rear has stacked blocks and the front has a single block.
So like Chris said I wouldnt use a 6" block.. Heck I wouldnt use a block at all if I could get away with it.. the shackle flip is a far better alternative, with better performance for not that much more $$.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-18-2006, 08:00 PM   #4
benoit454
Chris
benoit454's Avatar
I think rough country has the 6 inch block that's cast iron 1 piece.
However my rough country 4 inch lift kit came with cast iron rear blocks and they are tapered to help correct pinion angle.
Chris
GIT R DONE!!!!!!
Check out all our rides,
