Old 10-18-2006, 03:26 PM   #1
Machu10
Junior Member
Machu10's Avatar
Tilt Questions
Hey all,
I just received a rebuilt original truck tilt column that I ordered off ebay,
My question is do I need to do any special prep work to my truck to mount this column or do i need any other parts to make the swap? I know there is prep work involved for a van column, but I dont know what if anything I need to do to mount an original tilt.
72 Cheyenne Super ShortBox, Factory Big Block, A/C PS PB.
71 Cheyenne LWB, 350, A/C, 48k Miles
70 Olds Cutlass Convert, A/C, 350 auto, 66k actual miles.
82 Corvette, Triple Black, 32k Miles, Had since new.
85 Caprice Coupe, Bottle fed 383 Stroker, 30k miles.
06 Dodge Charger Daytona, Top Banana Hemi.
Machu10 is offline   Reply With Quote
Old 10-18-2006, 03:28 PM   #2
junkyardjohn
junkyardjohn's Avatar
Re: Tilt Questions
Nope... It Should Bolt Right In If It's Original. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 10-18-2006, 03:54 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Tilt Questions
If the turn signal switch was replaced durring the refurbishing, you may need an adapter for the plug. Look at the plug, if it is half moon shaped, then you are good to go... plug and play, if it is flat, then go to your dealer and order P/N189451, it should be about 10 bucks or so IIRC.
Old 10-18-2006, 06:53 PM   #4
Machu10
Junior Member
Machu10's Avatar
Re: Tilt Questions
Thx for the info,
I already have the wiring adapter with the column, so I should be good to go, might dive into it in the morning, I will let you guys know how it goes.
Old 10-18-2006, 10:28 PM   #5
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Re: Tilt Questions
Post some pics of the install
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
