Old 10-14-2006, 06:01 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
'67 burb lift kits
Just acquired a '67 suburban 4x4 1/2 ton. None of my local offroad shops can get lift kits for it. Can anyone recommend a place to order a 6 inch lift kit for my burb?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 10-14-2006, 07:51 PM   #2
69CvyPickup4x
69CvyPickup4x's Avatar
Re: '67 burb lift kits
check out www.offroaddesign.com
69CvyPickup4x is offline   Reply With Quote
Old 10-20-2006, 09:20 PM   #3
bad_turbo
turbo enthusiast
bad_turbo's Avatar
no luck there, I'll keep searching
Old 10-21-2006, 04:29 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have a '67 K/10 Sub myself, I wanted to put big El Rancho springs on it but the guy at the spring shop said I'd be better off having my original springs re-arched. Something about the spring mounts being in the wrong place for the after market products which are designed for the later model years.
Old 10-21-2006, 07:20 AM   #5
Americanrider
http://www.spring-man.com/
These guys can make it for you, anything from under to way over stock and they will also re-arch your old ones. I priced a new stock set for the front of my K-20 around 175 each, rears where 225 each. That was from the Tacoma store but Portland OR. will be closer to you.
Americanrider is offline   Reply With Quote
Old 10-21-2006, 01:15 PM   #6
kylejamers
ive gotten components made from this last link
and without a hitch, timely service, i would return
kylejamers is offline   Reply With Quote
