trans ques 3 plus granny
I have a 80 1 ton dump(pto) with the 3+granny trans. Ques is, what kind of trans is it? I am going to get a rebuild kit and was wondering if anyone knew what it was off hand. On another note, has anyone delt with 5speeds.com?
Thanks Jeremy
72 Chevy stepside shortbed 327 (currently) auto 3.73 posi 97 Chevy K2500 Turbo diesel (for sale) 03 DURAMAX crew cab 4x4 this truck kick butt ![]() |
junk collector
Re: trans ques 3 plus granny
sm465
'87/89/76 K5 in progress '99 K2500 short crew '91 camaro rs '98 jeep tj '52 willys cj3a |
sm stands for..... saganaw(sp)?
Location: vacaville ca, because it as far from indy as i can be
saginaw/muncie 465
thank you very much
Here's a breakdown of the SM465:
![]() Hope this helps ya. - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
Thanks, this tranny is making more noise every day, maybe this winter I will try to build it. Anyone every attempt a rebuild?
7000 #'s of american IRON
check synchro's (remember first is a NS gear so it wont make noise if it is the synchro)
Don't happen to have one of these for the heater/AC ducting do you?!?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
