Old 10-24-2006, 06:14 PM   #1
SSC's76
No No
SSC's76's Avatar
Pic request, trucks with a 3/4 drop.
I finaly broke down and ordered the belltech 3/4 drop kit. I was wondering if you guys would be so kind as to post a few pics of your trucks so I can get an idea of how the 76 will look. Also did a quick search but dial up is killing me, any issues running stok tire and wheels 235 75 15's? I wouldnt think there would be but I just gotta ask.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 10-24-2006, 08:11 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Pic request, trucks with a 3/4 drop.
Mine is lowered 2.5/4. I would post pics but my webhost messed up my photo gallery. There is a photo in my signature, but it is dropped 2.5/0 there.
I have no clearance issues with 15X8 rally wheels and 255/70/15 tires. Yours are smaller, so I doubt you will have any issues.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-25-2006, 08:03 AM   #3
beaterC10
I would expect you will have clearance issues with a 3" spindle and stock 8" ralleys. The problem will be with the ball joint area of the lower control arm rubbing on the inside of the wheel.
I have Belltech spindles and finally went with the 6.5" van ralleys on the front to help with the clearance. I also ground the lower lip down on the control arm. I removed enough of the lip on the outside edge of the arm that the lower surface of the ball joint extends past the outside edge of the control arm. The van ralleys seem to have the same backspacing as the truck ralleys, but the profile on the inside of the wheel is different and gives more clearance.
beaterC10 is offline   Reply With Quote
Old 10-25-2006, 09:33 AM   #4
Slonaker
Slonaker's Avatar
I'm glad you pointed that out. I assumed a 3/4 would be springs on the front and shackles/hangers on the rear. I should have take that into consideration. If your kit uses springs in the front, you should not have any problems. If it uses 3" spindles, you might have problems.
Slonaker
Stock '01 Silverado
Old 10-25-2006, 11:08 PM   #5
SSC's76
No No
SSC's76's Avatar
The kit does come with the 3'' drop spindles.
So would that mean I will have issues with my wheels? They are the 9" American Racing wheels?
Old 10-25-2006, 11:10 PM   #6
SSC's76
No No
SSC's76's Avatar
Pic.
Old 10-26-2006, 12:59 AM   #7
Slonaker
Slonaker's Avatar
I can't say for sure, but I suspect you will have clearance issues. It will probably depend on the offset the wheel has. That is why I went with the 2.5" Western Chassis drop spindles. I have no plans to run anything bigger than a 15" wheel, and I didn't want to take a chance.
What stock wheels and tires were you referring to in the original post? Those aren't stock...
Slonaker
Stock '01 Silverado
Old 10-26-2006, 08:20 AM   #8
beaterC10
I will concurr with Slonaker on interference with 3" spindles and alloy wheels. I had alloy wheels on my truck when I installed the Belltech spindles and replaced them with van ralleys. The alloy wheels had a thicker cross section than the ralleys and would not clear the underside of the lower control arm. I didn't pusue the alloy wheels since I had planned to install ralleys all along.
You might be able to solve the clearance issues with spacers behind the wheels.
Old 10-26-2006, 09:11 AM   #9
Slonaker
Slonaker's Avatar
...or a grinder, or both. I have not used the 3" spindles, but talked to several people here and elsewhere who had to do a lot of grinding on their lower control arm and/or brake caliper to get everything to clear. One person told me he did some grinding, used spacer, and went with a narrower rally wheel to get everything to clear.
Even with my 2.5" spindles, the LCA is very close to the edge of the 8" rally wheel.
Slonaker
Stock '01 Silverado
Old 10-26-2006, 09:43 AM   #10
SSC's76
No No
SSC's76's Avatar
Slonaker
I run two sets of wheels one is the AR in the picture the other is the ralleys from the 86. I was planning on switching back to the ralleys for winter use since I have a winter tire currently mounted on those wheels.
Old 10-26-2006, 02:20 PM   #11
Slonaker
Slonaker's Avatar
Got it. Those of us in south Texas don't think in terms of "winter tires." They are the same as our summer tires here.
Slonaker
Stock '01 Silverado
Old 10-26-2006, 06:10 PM   #12
magnethead
7000 #'s of american IRON
magnethead's Avatar
Slonaker
around here, you don't see either. All you see on trucks around here are either stock tires or 32+" M/T's. My friend's truck has 33x12.5's and they grab just about everything.
magnethead is offline   Reply With Quote
Old 10-29-2006, 12:28 PM   #13
SSC's76
No No
SSC's76's Avatar
I went out and took a peek at the lower control arm in relation to the rim. From what my eyeball measurments can tell it's only 2 1/4 from the bottem of the ball joint to the rim. It looks like the spindles will not work with these wheels.
