Old 10-24-2006, 03:34 PM   #1
Jason915
My new TBI Power
finally got all the bugs worked out of my TBI set up and now I am much happier. My PROM was programed too lean so I had it worked over and now it runs real good. My engine is a 350 .040 over with L-98 iron heads a mild CPU friendly CompCam headers otherwise factory GM TBI components. At first I was real disapointed with my power output and thought I would have been better off with a carb set up but now I am very glad that I didn't. It has real good low end great throttle response and it moves the old K5 better than the brakes are good for. Anyone planning on doing this swap its real easy and straight forward. Hit me up if you need some pointers
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 10-24-2006, 03:39 PM   #2
Burt4x4
Burt4x4's Avatar
Re: My new TBI Power
Cool! Congrats! FI is sooo sweeet , once you get it tuned right! hahhaa
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-24-2006, 05:09 PM   #3
Jason915
Yeah once tunned then you can just do the preventative maintenance and never bother with it. I really like the fact that it don't flood over on the steeps. My goal was to make it turn key have decent power and better MPG and driveability than a Carb set up. The MPG is not as good as I would have expected but that has alot to do with driving habbits.
Old 10-24-2006, 11:28 PM   #4
VinceY
Just need a couple more parts.
VinceY's Avatar
I am very interested in finding out some pointers. Would you have any time to submit something into a FAQ formate to help everyone?
1947 Studebaker M5 project to match the camping trailer.
1950 Chev 4x4 Pickup
1958 Shasta Airflyte Travel trailer (fresh restoration)
1971 C/10 Pickup(Frame off Restoration)
1972 K5 Blazer CST (Daily Driver & My Company Truck)
1976 Honda CB750 Bobber
1988 Jaguar XJ12
VinceY is offline   Reply With Quote
Old 10-25-2006, 12:09 AM   #5
krue
Designated A-hole!
krue's Avatar
Never too many faq's!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 10-25-2006, 09:00 AM   #6
Jason915
I did a write up in the FAQ section let me know if you have any questions.
http://67-72chevytrucks.com/vboard/s...ght=Conversion
Old 10-25-2006, 09:59 AM   #7
tpi72blazer
Tpi72Blazer
tpi72blazer's Avatar
Fuel injection is the only way to go. Once you've had it, you'll never go back to a carb.
Indian - the other money pit
tpi72blazer is offline   Reply With Quote
Old 10-28-2006, 07:05 AM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Why only just one pic?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-30-2006, 10:11 AM   #9
Jason915
LOL I'll post some more
Old 10-31-2006, 04:24 PM   #10
beaterC10
What are the numbers on the cam? I am looking doing something similar with a .030 over 350 that has an Edelbrock performer cam and L-98 heads. I forget the exact numbers but I think it has around .442 lift and something around 214 duration.
beaterC10 is offline   Reply With Quote
Old 10-31-2006, 04:33 PM   #11
Jason915
Intake Duration at 050 inch Lift: 206
Exhaust Duration at 050 inch Lift: 212
Duration at 050 inch Lift: 206 int./212 exh.
Advertised Intake Duration: 249
Advertised Exhaust Duration: 260
Advertised Duration: 249 int./260 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.434 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.444 in.
Valve Lift with Factory Rocker Arm Ratio: 0.434 int./0.444 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
It's a mild cam for low end torque smooth idle and good MPG
Old 10-31-2006, 05:01 PM   #12
nevada70chev
i got an 87 silverado w/ 5.7 tbi that i want to put into my 70, any and ALL help on the transplant would be GREATLY appreciated. i'm looking for better mileage and performance. i'll be using the 700r4 tranny also plus any other comforts i can get. thanks, any pics?
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 10-31-2006, 06:41 PM   #13
Jason915
Be sure to read this post in the FAQ.http://67-72chevytrucks.com/vboard/s...ght=Conversion You have the right idea to have a complete donor truck will make your swap go much eaiser than trying to peice together a set up. I would suggest a wiring harness investment it's $300 but it's well worth it I bought mine from painless. I also bought a TBI fuel pump it's a walbro inline FP that holley sells with their TBI Proinjection kit. I am very happy with mine, please feel free to ask any questions, good luck
