Its a Truck Thing......
4wd to 2wd
All,
tried to search it and got alot of different things but, how hard would it be to change a 4wd to a 2wd, I have everything for the front end ie spindles a arms and center link, Thanks, Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
Re: 4wd to 2wd
Their are alot of ways to go. You can just use a stock 2wd front crossmember and drill alot of holes or if you want it nice and low I would go with a Dropmember from Porterbuilt here on the site. For teh real just go with lowered leaf springs, install a four link and coil/bags or get a stock 2wd trailing arm crossmember and trailing arms and have a stock set up.
Kevin LFD Inc. |
Re: 4wd to 2wd
Are the front crossmebers different?
#4 | |
Re: 4wd to 2wd
![]() just remove the front drive shaft...just kidding Last edited by msgross; 10-25-2006 at 11:39 PM. |
![]() Join Date: Aug 2005
Re: 4wd to 2wd
Here. Check this out. It's for a different body style but it might help.
http://67-72chevytrucks.com/vboard/s...d.php?t=168231
'73 C-30 3+3 Dually 454/TH400 '74 Fleetside 350/TH350 (SOLD) '69 Nova 350/TH350 (project FOR SALE) '63 Nova 305/TH350 3.73 posi (the wife's project) Last edited by bad_burb; 10-25-2006 at 11:55 PM. |
Re: 4wd to 2wd
Interesting,
Re: 4wd to 2wd
You would think all the holes would already be there.....we shall see..
MY EX DRIVES A BROOM
Re: 4wd to 2wd
good luck with the swap, if you have any questions i will try to answer them as best i can
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
