Old 10-20-2006, 08:03 PM   #1
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
drop spindle
Forgive my ignorance, but the PO had put disc brakes and spindles on the front of my truck b4 I got it and I'm trying to figure out if they're 73-87 spindles or if they are aftermarket drop spindles. My truck is bagged and at full dump I still have like 2 inches or so between the concrete and the front crossmember. My cups are cut down to 1/2" in height, so they are not limiting me. Anyone have any pics of drop spindles vs. stock spindles so I can identify what I have? I tried looking at McGaughys and Belltech but their sites aren't so hot for detailed pics.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-20-2006, 08:39 PM   #2
jimmydean
jimmydean's Avatar
Re: drop spindle
Drop on the left, stock on the right:
Notice the stock spindle is near the bottom, level with the tie rod mount.
jimmydean is offline   Reply With Quote
Old 10-20-2006, 10:11 PM   #3
hotrodhomi
hotrodhomi's Avatar
Re: drop spindle
I think your A arms will hit b4 your crossmember.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 10-20-2006, 11:29 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: drop spindle
That is correct. This is my 82 Blazer with 3" drop sindles.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-21-2006, 10:25 AM   #5
67Fleet
67Fleet's Avatar
Re: drop spindle
thanks guys! That helps a ton.
-Bret
Old 10-23-2006, 08:04 PM   #6
st1x10
st1x10's Avatar
Re: drop spindle
What are the differences between the 71-72 spindles and the 73 and up? I was wondering because my truck is 5 lug with disc and I don't know what kinda spindles they are to buy parts for it.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 10-26-2006, 03:11 PM   #7
craig@ridetech.com
Formerly LSC71
Re: drop spindle
There isn't a whole lot of difference other than they used different upper ball joints in 71-72 than on 73-up. Haven't tried to swap the balljoints in the two different arms but I do know that is one of the main differences.
craig@ridetech.com is offline   Reply With Quote
Old 10-26-2006, 08:15 PM   #8
st1x10
st1x10's Avatar
Re: drop spindle
Are the brake rotors the same between 72 and 73? Also any way to id besides the balljoints. Here is a pic of mine if that helps.
I need new rotors and pads is why I am wondering. Thanks
2002 Chevy S10 V6
Old 10-27-2006, 08:49 AM   #9
craig@ridetech.com
Formerly LSC71
Re: drop spindle
I can't say for sure if they are the same. I do know, however, that you can swap the brake calipers from the two. The only change I had to make was where the "banjo"style fitting bolts in, you have to do a little grinding for it to seat right and get a good seal.
