Old 10-20-2006, 09:04 AM   #26
texascowboy593
texascowboy593's Avatar
Re: 1951 Project underway
Good progress and score on evil-bay. Hope you get alot done before that real cold air arrives! Its like 50 degrees here this morning and its COLD for here!!!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 10-20-2006, 12:39 PM   #27
Daniel U
Daniel U's Avatar
Looks like you've been busy! Keep it up, Winter is on the way.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 10-23-2006, 03:27 PM   #28
bretcopsey
Well, for reasons I'd rather not bore you all with, all I got done this weekend was removing the bed and cleaning up the garage while the truck was in the driveway. Hopefully next weekend will prove to be more productive.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 10-23-2006, 04:47 PM   #29
Blue85
Oilfield Trash
Blue85's Avatar
what year camaro clip did you use, is it the same width as the stock front end?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 10-23-2006, 04:52 PM   #30
bretcopsey
I used the clip from a 79 Camaro. The track width is greater than the original by a couple inches. I'll just make up for it with wheel offset though.
My 51 project
Old 10-29-2006, 03:18 PM   #31
Low84
Low84's Avatar
Thanks, you just gave me a new light of hope for my '51. Really.
Do you think your rust treatment method would work on this (hope you don't mind):
From the cab forward, I realize the bed is pretty much a total loss.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 10-30-2006, 09:23 AM   #32
bretcopsey
Low84,
The firewall here at work won't let me see your picture. I'll check it out tonight at home. To answer your question as best I can now though, the metal needs to be in good enough condition that it isn't flimsy or rusted through. Basically, if you would be able to sand the rust off, you could use the acid instead. Deep pitting can still reamain after fully cleaned, but as long as it isn't going to cause any structural weakness to the metal, then you can just use a filler or filler primer to smooth it all out.
I got to work on my truck for a few hours yesterday, and how I wish I could figure out a way to use this method on the cab as well! I sanded for a while, then turned my attention to cutting out the dr side cab corner. It's just so much easier to let a solution eat the rust away then to sand it off!!
My 51 project
Old 10-30-2006, 12:07 PM   #33
Low84
Low84's Avatar
Alright, I appreciate that. I removed the bed from the chassis yesterday, and the bed is pretty much a total loss. The front bed panel is unsaveable, and the bed side panels seem to have lost strength but I couldn't find any rust on them. Might go ahead and replace them anyway. I did start to sand down the surface rust on the chassis and gave it a protection coating.
So, I take it this acid rust treatment is only for parts that can be dipped, correct?
Old 10-30-2006, 12:32 PM   #34
bretcopsey
It is not limited to parts that can be dipped, but the reaction is somewhat slow, and the surface needs to remain wet. For example, I'd love to do my cab, but I would need to find a way to keep a 'shower' going to be effective. I would also need to come up with a way to catch the runoff. I also would be leary of the runoff going down the frame and dripping where it may.
I have had success removing light surface rust using a scotchbrite over a bucket. But for the heavier surface rust I am dealing with, I don't think that would be an effective option.
My 51 project
Old 10-30-2006, 12:46 PM   #35
Daniel U
Daniel U's Avatar
If you plan on using the chassis, sand blast it. Check Harbor Frieght for kits. They aren't too exspensive. Don't sand blast body panels though, the will warp when they get too hot. Also, remember to etch prime the metal before painting. This seals the metal to prevent rust in the future.
Old 10-30-2006, 01:06 PM   #36
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Hey Brett,
I had a couple in that year range and I love those body styles. Have you thought about a little backyard pond pump? They come in many differant flow ratings, but I'm not sure how they would handle an acid bath. Just a thought. Keep up the good work.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 10-30-2006, 01:17 PM   #37
Low84
Low84's Avatar
bretcopsey,
Thanks for clearing that up.
Daniel U,
Thanks for the advise. I checked the website out and the prices aren't bad at all.
Didn't mean to hijack your thread bretcopsey, sorry. I just got excited, thats all. I'll start my own build up thread. So if you guys are still willing, you can help me over there.
Old 10-31-2006, 07:51 AM   #38
bretcopsey
You should have no problem using this method!
My 51 project
Old 10-31-2006, 07:54 AM   #39
bretcopsey
I think I finally found the 'correct' phosphoric acid at Home Depot. It is available in quart or gallon in the section with the paint thinner etc. Made by Klean Strip, called Phosphoric Etch & Prime (or somehing like that) I'll double check tonight. No more using solutions made for other purposes etc! A gallon was like $13.95 so I bought a few.
*EDIT Phosphoric Prep & Etch*
My 51 project
Old 11-06-2006, 11:03 AM   #40
bretcopsey
Originally Posted by Bishops Trucks View Post
Hey Brett,
Somehow i missed your question. I have a submersable pump that flows like crazy. It's actually too much force for my comfort level. I've thought about using a small pump like for a fountain. I'm still leary of making a huge mess though!
This weekend I knocked the rust off the rear 1/2 of the frame with a twisted wire cup then followed that up with a spray of phosphoric acid. I filled a spray bottle and lightly misted everything-and it worked great! Of course, I was wearing a long sleeve shirt, gloves and safety glasses! I also was the only one outside during this.
I decided to try that on the cab as well. I lightly sprayed it, then 'wet sanded' the rust. I just had to keep it wet, and a lot of elbow grease was involed. But it went much better than if I had only 'dry sanded.' I still have a long way to go, but it's progress! I'll try to update with some pictures tonight.
My 51 project
Old 11-07-2006, 12:48 PM   #41
bretcopsey
Here's a picture of the inner cab corner after I cut away the outer cab corner. I know patches are available for this, but since the areas are so small I'm going to try to patch it up with some scrap. Once I get that done I'll make better cuts for replacing the outer corner.
There's also a picture of the rear portion of the frame in it's current state. That finish is only from the 'acid prep' mist. I still need t get some paint on it.
My 51 project
Old 11-07-2006, 12:50 PM   #42
bretcopsey
And here's the back of the cab as well as the cab roof. I still have a long way to go, but it's some progress!
My 51 project
Old 11-07-2006, 04:24 PM   #43
Daniel U
Daniel U's Avatar
Once again, I admire your enthusiasm/ambition!
Old 11-10-2006, 01:31 AM   #44
bretcopsey
Thanks Daniel!
I've taken the last few days off. Here's the prgress on the roof after about 2 more hours work tonight. I was going to just get the cab blasted, but the guy told me he wouldn't touch the roof for fear of warping it. So, here I am, sanding away!
My 51 project
Old 11-11-2006, 08:14 PM   #45
72CSTC5
72CSTC5's Avatar
Make sure you guys neutralize all that acid you are putting on there with baking soda and water to get good clean metal again. I would hate for that acid to come back up through your paint job.
72CSTC5 is offline   Reply With Quote
Old 11-25-2006, 01:56 AM   #46
bretcopsey
Although the directions state to rinse with water, I'm going to experiment by treating then painting some scrap before moving on to the truck.
This is as far as I have gotten with the cab to date.
My 51 project
Old 12-22-2006, 01:05 AM   #47
bretcopsey
Just a small update. I replaced the dr side cab corner. Then I began fitting up the door to replace the cowl panel when the upper hinge pin broke. So I need to take some time to rebuild them. Hopefully that won't be too painful of a process.
My 51 project
Old 12-22-2006, 10:03 AM   #48
pgf545
pgf545's Avatar
Bret, Take lots of pictures of the cowl replacement, I am fixin to do that on my dads truck.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 12-22-2006, 10:07 AM   #49
bretcopsey
Bernie
Bernie, I'm only doing the dr side cowl, but will take a bunch of pics if that is what you need. It should be pretty straight forward. Post 47, picture 2 above shows where I had to drill out some spotwelds. Also, post 46 picture 2 shows the panel mocked into place. Let me kow what else you need to see!
My 51 project
Old 12-22-2006, 10:21 AM   #50
Jebb1978
Jebb1978's Avatar
Man this thread is an inspiration! You have come a long way!
1959 GMC project
Jebb1978 is offline   Reply With Quote
