Old 11-02-2006, 12:17 AM   #1
bambam23
freeze plugs
Hey guys,
I was just wondering how difficult it was to replace the rear freeze plug on my 77 Custom Deluxe. It's got a 350. Never done one before, so whatever info I can get would be great. Thanks!
bambam23 is offline   Reply With Quote
Old 11-02-2006, 06:36 AM   #2
blaserman
blaserman's Avatar
Re: freeze plugs
Very easy to replace but you might have a little problem getting to them in the back. Just take a flat tip screw driver and remove it if it is loose. If it is tight I put a large screw through it and used a pair of vice grips to pull it out. Clean the area real good and put some gasket sealer on it and tap it back in gentley, I used a large socket to keep it centered.
This is my best friend
blaserman is offline   Reply With Quote
