Active Member
![]() Join Date: Oct 2006
Suspension difference
Was just wondering what the difference was between a 67-72 fornt suspension and a 73-87 front? The reason I ask is because I see alot of people switching. Is there a better ride, or is it just for disc brake reasons?
A guy with a truck
Re: Suspension difference
Disc brakes, rubber bushed arms and cheap, readily available parts. Other than that, basically the same thing.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Active Member
Another reason I ask is because my friend has an 81 and is running 20x10 rims on the front with no clearence issues, and I have 20x9.5 and I rub the a-arm should I switch to that style a-arm to fix it or is there a better fix?
A guy with a truck
Where is your clearance issue? Dimensions of the arms are very close between the early and late parts. Either of you running a drop spindle? This could be the difference.
Active Member
Thats what I figured my rubbing is on the a-arm during a full right turn. But he running them and I am not that is probably the difference because it would lift the rim up higher. I knew it did not sound right because I know alot of guys running a 10" rim on the front.
Outlandish Trends - FL
Also depends on backspacing. What is his backspacing compared to yours? There is a 1/2" difference in total wheel width if they are the same, which equates to 1/4" more on the inside for his wheels. There's got to be a difference in backspacing.
-Bret 67 short-fleet sold! |
Active Member
I don't know exactly but I will find out. At least they don't rub the fender.
