Gas gauge wont work!!!!!
The gas gauge in my 72 custom deluxe absolutley refuses to work. Its stuck at like a little over half a tank. I've had the cluster out numerous times and have installed aftermarket gauges for the bottom three and a tach in the middle. Im not sure if it has ever worked, i wanna say that it did before i took it out
Re: Gas gauge wont work!!!!!
Did you check to see if it had a ground wire?I had to run a grd. when I changed out my cluster.
77 swb starting all over again. |
A factory ground wire hooked up? Or have to add one? Why would i if i just plugged it back in? I dont have any clue
Black 72 Chevy
One quick check you can do to see if it works is disconnect the single wire from the gas tank sending unit. The meter should go to full. If you short the wire from the sending until to ground, the meter should read empty.
And if all that goes as planned, what would be the problem? Sending Unit?
Black 72 Chevy
Sending unit.
![]() Join Date: Oct 2006
A.P. is right just backwards. disconnect the power wire to the tank,the guage will fall to empty(no power),then ground the wire and the guage will read full.(do all this with the key on) If the guage does not change readings then you either have a bad connection(doubtful)or the guage is faulty.If the guage does change readings then the sending unit /float could be the culprit.-Sorry A.P. not trying to step on your toes!
Black 72 Chevy
manimal thanks for the correction, it been a long time since I worked on the electrical on my truck.
A.P. |
check the resistance at the tank
check the resistance at the fuse box connection check the resistance at the back of the cluster connector it should be between 0-90 0-empty 90-full |
Not a problem A.P.
#11 | |
![]() Join Date: Jul 2004
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Green Machine and A.P. you are both right, I just went and checked my 72 and you are right -MY SINCERE APOLOGY! My experience with troubleshooting fuel guage problems are from working on the old ford cars and trucks that I buy and sell. VERY SORRY AGAIN!
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Thanks a lot everybody i'll have to try that.
