Bed Mounting
Is there a recommended way to level the truck bed? Obviously you unbolt it and start shimming but I thought someone might have some thoughts on how do this best. Seems to me that I should start at the cab end and shim each connection to correct heighth and then move back?
Thanks, Whit |
![]() Join Date: Jul 2004
Re: Bed Mounting
Unless the frame or box is really off, the box should be a bolt on the the frame and go. Usually the rear of the cab will need to be shimmed and moved to get it straight and level with the box, and usually one cab corner will need an extra shim or two to get it straight with the box. Do you have any pictures ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Re: Bed Mounting
I'd like to know how you guys are shimmyin the trucks too
after more than a year I think my bed and frame are going to reunite! I put poly in the body mounts. what are you guys usin pics would be extreamly helpful |
#4 | |
Re: Bed Mounting
Thanks, Whit |
Too many projects
Re: Bed Mounting
Where are ya'll putting the shim for the cab? Between cab and rubber or between rubber and frame? I guess cab/rubber, but I'm away from my baby right now so I can't look.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
Re: Bed Mounting
#16876
Re: Bed Mounting
Did you put in new cab mounts, or use the old ones? You can buy rubber cushions for between the bed mounts.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
Re: Bed Mounting
The rubber shims are a good idea for between the frame and bed. You can buy a tar fabric material of varying thickness and width in whatever length you want from old car restoration places. I think it's called "anti-squeak". Cut it in 2x2 or 3X3 in. squares and cut a hole for the bolt. This may sound like a backwoods idea but If you have access to old fire hoses, they would make awesome (and durable) cushions for the same purpose.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() Last edited by Sweet72; 11-04-2006 at 05:02 PM. |
