Old 11-06-2006, 04:51 PM   #1
67chevemall
67chevemall's Avatar
wrench for the dizzy?
Hello
What are you guys using to get at the dizzy bolt. My bent wrench just isn't doing it. It gets hot in there.
What is the special tool to buy for no headacke timing ?
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 11-06-2006, 04:54 PM   #2
zden
Re: wrench for the dizzy?
you can pick up a wrench at most parts stores that is basically 2 L shaped sides that snap together.
1966 Chevrolet Suburban
1955 Chevrolet Bel Air
zden is offline   Reply With Quote
Old 11-06-2006, 04:57 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
What Zden said....
I think I got mine at Harbor Freight. Works good.
LockDoc
Leon
Old 11-06-2006, 05:19 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There should be plenty of room on a small block chevy to just, put a wrench on it.
Old 11-06-2006, 05:39 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Yeah on a small block I have always used a regular 'ol 9/16" wrench, but for the last 10 years or so I have been using a header bolt, so then I use a 3/8" wrench.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-06-2006, 07:48 PM   #6
Jim_PA
Doesn't work for me very well.
I use a 9/16 swivel socket and a long extension. It works OK -- it's a tight angle on the swivel socket, but it gets the job done.
I was just at sears yesterday, and they had actual distributor wrenches in 3 different sizes, and I'M SURE -- they would work perfect. I think they were 7 or 8 bucks.
Jim_PA is offline   Reply With Quote
Old 11-06-2006, 08:17 PM   #7
jacobs
jacobs's Avatar
High end tool companies ie Snap-on should be able to supply one. That's where I got mine 30 years ago.
jacobs is offline   Reply With Quote
Old 11-06-2006, 08:34 PM   #8
panhandler62
Java Mechanic
panhandler62's Avatar
I'm usualy sitting on my radiator when I work on the motor. (Yes, it's relevant! lol)
I don't have any difficulty using a standard box wrench, but that is likely due to the angle I am comming at it from.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 11-06-2006, 10:13 PM   #9
krue
Designated A-hole!
krue's Avatar
Hands down the best wrench is the flexhead gearwrench ratchet wrench. It's like it was made for the dizzy holddown bolt.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-06-2006, 10:24 PM   #10
I am the oddball I guess. One of only three professional tools I have. I have a snap-on a 9/16 and 1/2 distributor wrenchesas well as a pivot pin puller. I love the distributor wrenches. Of course I use them for more than on distributors. I used some a few years ago when I was working on my 82 C10 and they were great, that I had to get me some. Much smaller head and good reach to fit in tight or confined areas around bolt head. I haven't been rich enough to buy any other snap-on tools.
Mine is a bit tight, but my V8 sits in the 6-banger slot.
Old 11-06-2006, 10:53 PM   #11
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
you can get one at napa autos, the are basicaly a piece of 3/8" solid rod with a 9/16" box end with 2 90* bends and it works pretty damn well for $8.
trkklr77 is offline   Reply With Quote
Old 11-07-2006, 12:02 AM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
That's what I use, but it is close quarters on a K20...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-07-2006, 12:27 AM   #13
jimmydean
jimmydean's Avatar
That's what I use and it works great. I bought a special wrench from Autozone, but it's kinda funky to use. My flexhead works best.
jimmydean is offline   Reply With Quote
Old 11-07-2006, 12:36 AM   #14
LockDoc
LockDoc's Avatar
There's usually enough room but it seems like everytime I want to loosen or tighten it the motor is hot. That's why I went ahead and sprang for the dist. wrench..... Glad I did.
LockDoc
Leon
Old 11-07-2006, 05:25 AM   #15
junkyardjohn
junkyardjohn's Avatar
I've Got About 1/2 Dozen Different Shaped 9/16" Snap-on Dist. Wrenches That I Bought At Pawn Shops For $12 To $15 Each. Man There Is Nothing You Can't Do If You Have The Right Tools. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-07-2006, 11:32 AM   #16
mrein3
mrein3's Avatar
If you own a 67-72 I believe there are three tools you MUST have. You can get by without any of them however the time saved by owning them is huge.
1. The wrench everybody is talking about in this thread. Mine still has the price tag on it from the used tool store. $15. It is a snap-on.
2. Is a wrench made by kd tools. I'm sure others make them. It has a 3/8ths on one side and a 5/16ths on the other. When you bleed brakes other tools work, however this one works the best.
3. I owned my Chevelle for 10 or so years before I bought this gem. I used little screwdrivers, fuse pullers, and other similar tools to get the horse shoe clip off the door handle or window crank. The clip always goes flying. You are always complaining. Then I bought this tool. Slip the tool behind the crank or handle, the clip slides off and doesn't go flying.
That whole box of tools set me back less than $30. You can't calculate how much time each one saves EVERY time you use it. What is your time worth?
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 11-07-2006, 06:19 PM   #17
67chevemall
great info. #1 is what I was lookn for. Thanks I need one of those I can't climb so far in anymore.lol
New bolt too she is a little stripped.
Cheers
Old 11-07-2006, 10:31 PM   #18
Jim_PA
Maybe I have a strange bolt, but I CANNOT do it with a standard wrench, I can get it so far, then the bolt is simply in the wrong position to get another grab on the head of the bolt to tighten it any more.
Old 11-08-2006, 12:34 AM   #19
jimfulco
I use a short (5" or so) offset 1/2"x9/16" 12-point box-end. One tooth at a time, sometimes.
jimfulco is offline   Reply With Quote
