11-03-2006, 03:04 PM | #1 |
Inline 6 exhaust leaks
Can anybody help me find a source for a better quality exhaust gasket? I had the manifold surfaced but the head has some minor pitting an the stock (metal on both sides gasket) just isn't making it.
11-03-2006, 03:09 PM | #2 |
Re: Inline 6 exhaust leaks
I think you need 2 gaskets one for each side of the 4 cylinders. So pull the motor and slap in a small block. No just kidding, you should be able to get Fel Pro in a synthetic gasket and not all metal one.
11-03-2006, 04:36 PM | #3 |
I used some Permatex High-Temp Ultra Copper RTV Silicone Gasket Maker on my 250 with NAPA gaskets and never had a leak or an issue.
11-03-2006, 08:52 PM | #4 |
Out of the carpool lane.
When you machined the manifold did you have them both bolted up together? Or did you only do the exhaust?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
11-03-2006, 09:05 PM | #5 |
They were bolted together with a new gasket that didn't leak.
11-04-2006, 02:37 AM | #6 |
Take a look at my post (3rd one down) here:http://67-72chevytrucks.com/vboard/s...d.php?t=209362
This is a good way to make sure everything seals well. If you still have an exhaust leak, could it be coming from the area where the donut is? That's been a problem for me when I had stock exhaust. Make sure the tail pipe is squared up to the outlet port when you're bolting it all together and always use a brand new exhaust donut. Let us know...
11-04-2006, 07:59 AM | #7 |
I've had to replace some of the OEM bolt fasteners with studs. Especially on the ends [#1 + #8], where the stock set up uses non-threaded guide pins.
Of course I'm running an Offy intake and Clifford headers on a 292 L6, but studs [3/8-16 UNC_3/8-20 fine thread] would give you much better holding even with a stock manifold. For the gasket, the FelPro metal one [with Permatex Copper-Spray-A-Gasket] ought to work. The NAPA one is the same thing.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 11-04-2006 at 08:07 AM. Reason: more stuff |
11-07-2006, 12:35 AM | #8 |
Just curious --- are the fixed studs at the ends threaded into the head or do you have to drill and tap? The latter would not be an inframe chore as I see it.
11-07-2006, 01:07 AM | #9 |
They are screwed in. Just get a Vice-Grip plier and unscrew.
11-07-2006, 08:00 AM | #10 |
They come out CCW with some WD40, big vice grips and a small ball pien. The holes are already tapped 3/8-16 UNC. The studs are about 3" long and the first inch is threaded 3/8-16 then about 1/2 inch of non-thread and ending with about 3/4 of a finer thread 3/8-20 -or -24 [whichever]. Common at fastener suppliers. A flat washer, a lock washer and the nut complete the set up.
