Old 11-08-2006, 02:08 AM   #1
redneckdds
redneckdds's Avatar
Spark plug wire looms
which looms are yall running? I want a nice clean look, I have a 350 with Hedman elite headers if it helps.
'67/70 Chevy C/10
'10 2500 Crewcab Duramax 4wd
redneckdds is offline   Reply With Quote
Old 11-08-2006, 08:36 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Spark plug wire looms
I have the blue anodized type that run along the valve covers. They go from 4 wire holders in the rear to 1 in the front. I have an extra chrome set that have never been used I am planning to list for sale on the board soon.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-08-2006, 09:00 AM   #3
pkj
70c10 if you do, let me know. been thinking about those myself. pkj
pkj is offline   Reply With Quote
Old 11-08-2006, 09:03 AM   #4
72freak
Rottenwood Garage Member
72freak's Avatar
These are what was on this truck when I got it. I need to change the wires to block but i will probably leave the looms.
72freak is offline   Reply With Quote
Old 11-08-2006, 09:04 AM   #5
jamon8
jamon8's Avatar
go under the header
jamon8 is offline   Reply With Quote
Old 11-08-2006, 10:28 AM   #6
rodstored-72
chevy truck fan
rodstored-72's Avatar
i am running the billit specialtiies plain style. they cover the wire from just at the plug to the rear of the vlv cover. i think they were around $60 i would have to look at the papers again though...
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 11-08-2006, 03:11 PM   #7
Jim_PA
Originally Posted by jamon8 View Post
go under the header
that gets my vote
Jim_PA is offline   Reply With Quote
Old 11-08-2006, 04:12 PM   #8
70c10
67-72 Addict!
70c10's Avatar
They look similar to 72 freak's. How would you guys mount the looms under the header when the looms are mounted to the valve cover bolts?
Jim
Old 11-08-2006, 04:35 PM   #9
Jim_PA
You don't use any looms when you mount them under the header. In fact, you can't hardly see the plug wires at all.
Old 11-08-2006, 05:05 PM   #10
70c10
67-72 Addict!
70c10's Avatar
Oh, ok.
Jim
Old 11-08-2006, 05:20 PM   #11
Jim_PA
Oh, ok.
I think plug wires clutter up the engine compartment, and just get in the way. I don't see the reason to showcase plug wires, so I mounted mine like this:
Old 11-08-2006, 05:27 PM   #12
70c10
67-72 Addict!
70c10's Avatar
What supports the wires?. Or do they just stay rigid enough to not flop around?
Jim
Old 11-08-2006, 05:36 PM   #13
Jim_PA
On my block, there was a bolt hole in the center of the block, at the top (on both sides) for.... a heat shiled, maybe???
I made a small flat bracket that points downward, and runs almost along the block, then I neatly used tie wraps to make sort of a wiring harness out of all 4 plug wires on each side, so each wire would only reach the plug it needs to reach and keeps the wires away from the headers -- the group of wires is held to the small bracket by another tie wrap or 2 Simple, effective, appealing, and best of all FREE!!! (except for the tie wraps)
Old 11-08-2006, 08:02 PM   #14
67chevemall
67chevemall's Avatar
This is BIG news! heat rises too! I'm all over it. That old trick using wire ties to make looms(one inside the other) should keep em together.
4sure
67chevemall is offline   Reply With Quote
Old 11-08-2006, 08:09 PM   #15
67chevemall
gotta get dam hot in here though maybe some loom
on 1 -4 ?
Looks and sounds like a better route to go.
Have to see how they run under there.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
Old 11-08-2006, 10:20 PM   #16
Jim_PA
The wires are no closer to the header than they would be if I ran them over the top. Here's a closeup of those areas.
Old 11-08-2006, 10:33 PM   #17
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
I hate to admit it but right now but my wires are just held back from the ramshorns with Zip ties.
ND_guy is offline   Reply With Quote
Old 11-09-2006, 04:44 AM   #18
OhioDan
OhioDan's Avatar
Thumbs up Re: Spark plug wire looms
Mine go under the exh. manifolds. Used stock wire stands. Most venders have them. Got mine from GMC Paul. Keeps wires out of the way.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-09-2006, 09:19 AM   #19
72freak
72freak's Avatar
Most all of my other vehicle have them run under, but then again, since I HATE headers all my other vehicle have exhaust manifolds...... so it is a bit easier to run them.
