cutting floor to make a high hump
Any pix/advice/warnings or how to's, to convert a low hump to a high hump.
I am swapping cabs on my 67 4/4 and want the floor to look factory. As far as I can tell the floors are a little different in the way they are stamped. Do I cut out the high hump floor and weld it to the low hump floor? Will the high hump cover bolt flat to the low hump floor? Thanks, Steve |
Re: cutting floor to make a high hump
For got to add that the cab I am replacing came with buddy bucket seats
good question i'm interested in this information also so TTT for you anybody tried this conversion???
![]() Join Date: Aug 2001
me three.
The high hump bolts to the floor,you need to cut out the low hump by using measurements from the high hump and drill holes for the hump to bolt to in your floor.I was/am in the same situation.
I have a thread in the suspension forum entitled 'Dropmember in a 69 C-10' It has some pics of this conversion.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Place the hump in the right spot. Use a sharpy or other marker to outline the high hump and also mark the holes. Pull up the hump and cut inside the bolt circles. There may a crease in the floor(my brother is doing this currently and mentioned the crease).
Make sure you leave enough to support the hump. You can always make the hole bigger but it's hard to make it smaller.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
![]() Join Date: Feb 2000
I did the reverse of what you are doing but it worked without a hitch so I thought I would chime in. I put a low hump in my 4x4 cab because I was using a body lift and using the low hump helped avoid transfer case shifter issues.
Here are a bunch of pics I took of the 4x4 high hump next to a low hump cut out of a 2wd. They may or may not be of any interest as you do this job. ![]() ![]() ![]() ![]() ![]() ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Active Member
Anybody out there have a "low hump" floor panel they wanna donate to a good cause ? I have a nearly perfect 4x4 auto high hump to trade.
Mac --'67 Step, ZZ4 |
How much of it do you need?
Pm me , I have a parts cab. Thanks, Steve |
