Old 11-10-2006, 08:24 PM   #1
mofo69
mofo69's Avatar
2 link or 4 link,pros and cons
I was wondering if anybody had some useful info on 2 link or 4 link set ups. I really want to ditch the trailing arms so the rear can layout. Also does this site still have galleries. It's been awhile since I was on here last. Any help would be appreciated
mofo69 is offline   Reply With Quote
Old 11-10-2006, 11:44 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: 2 link or 4 link,pros and cons
There is a lot more info for you in the Suspension forum.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-11-2006, 01:19 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Very true, so I moved it there...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-11-2006, 01:22 AM   #4
bagged_gmc
Shaved
bagged_gmc's Avatar
Ok...The name of the game is pinion angle...a 4-link allows correct pinion angle...a 2-link does not...for the amount of suspension travel a bagged truck will have, then a 4-link is the proper way to go. A 2-link WOULD WORK, yet would not be the safest or most reliable choice.
bagged_gmc is offline   Reply With Quote
Old 11-11-2006, 04:18 AM   #5
thekid54
I agree with bagged_gmc on the pinion angle comment.
However, 2-links aren't as bad some people make them out to be. For example, c-10's were produced for many years with a 2-link suspension, and it worked, and still works good. If you are going to bag your truck then pinion angle will be an issue. I personally went with a 2-link for my truck because I don't plan on varying my ride height that much while driving. I set it up for a ride height of 4.5" (lowest point of frame to the ground) and when aired out will lay frame. I set the pinion angle at this ride height because that's how I plan to drive it most of the time. If you max out your bags to get over a bump or go up a drive way momentarily, then it's not going to be too hard on your u-joints. Just my 2 cents.
thekid54 is offline   Reply With Quote
Old 11-11-2006, 10:38 AM   #6
rancid
rancid's Avatar
anybody know where to buy a nice 2 link kit, i just shortened my gmc from a longbed to a shortbed and want to convert it to a 2 link.
rancid is offline   Reply With Quote
Old 11-11-2006, 10:44 AM   #7
PBFAB.COM
PBFAB.COM's Avatar
I just pulled the trailing arm set-up out of a 66 I am four-linking... PM me if you are interested.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-11-2006, 12:50 PM   #8
mofo69
mofo69's Avatar
thanks for the input. What about the galleries, there are many rides that I would like to see in more detail.
Old 11-11-2006, 05:27 PM   #9
SCOTI
SCOTI's Avatar
The main reason the 62~72 2-link (aka trailing arm suspensions) work is because of the length & orientation of the arms within the chassis.
Most 2-link 'kits' are actually 2 'links' that are typically parallel to the frame/chassis & less than half the length of the 62~72 trailing arms. There was a thread @ bagit.com (or baginit.com?) about pinion angle change during suspension extension/compression when using this shorter style 2-link. It is a very good read. I did the little experiment that was suggested & was suprised to see almost 12deg of pinion angle change @ less than 4" total suspension movement w/a typical length 24" link (the 24" link is what would typically be used if swapping a leaf suspension over to a 2-link using the stock front leaf hangers).
That's a lot of change & even if you set the proper pinion angle @ the avg ride height, theres still a bunch of change w/the typical 2" of rebound or extension you'll experience driving down the road.
Just food for thought. I would suggest a 4-link for something that sees regular street duty & the 2-link for the weekend show warrior unless it's the 62~72 truck arm 2-link. We all know they work quite well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-12-2006, 08:59 PM   #10
thekid54
Yes SCOTI is right. I forgot to mention how the length of the arms factors in. I made my arms as long as possible without interfering with the cab mounts. Mine are about 10" shorter than the stock ones. My friend adapted a '62-'72 truck susp. into his '51 chevy coupe with air bags, works real nice!
Old 11-12-2006, 11:24 PM   #11
Shane
Shane's Avatar
I'm not 100% on this, but I don't think this board ever had a "gallery" ... at least not that I can remember.
Shane is offline   Reply With Quote
Old 11-13-2006, 12:24 PM   #12
Tony@AirRideTech
Junior Member
Good post man The trailing arms and a two link realy have nothing in common other than they look similar and have two connecting point. The geometry of a trailing arm system accounts for pinion angle change and axle articulation by the length of the arm being equal or close to equal length of the driveshaft. Plus the mounting of the arms angling inboard towards the center of the chassis from out on the axle ends allows for articulation. A conventional 2- link does not account for either of these scenarios.
Tony@AirRideTech is offline   Reply With Quote
Old 12-11-2006, 05:09 AM   #13
BigShoe24
True Addiction
BigShoe24's Avatar
So I could get away with a kpcomponent step-notch, cpp trailing arms in the stock location, and mount my bags on front of the rear end? I have a 70sw and was worried about driveshaft problems, single driveshaft? Thanks for any suggestions.
BigShoe24 is offline   Reply With Quote
