Old 11-03-2006, 04:06 PM   #1
stynchrr
stynchrr's Avatar
Parts I need WTB
I got a couple of parts i have been looking for:
1. Turbo 400 Pedal kickdown switch and wires
2. Springs to repair the bottom driverside of a bench seat that has spring core not the foam
3. Brake booster bracket that goes from the maaster cylinder bolt to the fire wall
4. Power steering pump and brackets for sbc swp with add on crank pulley
5. Lower or upper 3 core rad mount
stynchrr is offline   Reply With Quote
Old 11-03-2006, 06:55 PM   #2
Ironhorse
Ironhorse's Avatar
Re: Parts I need WTB
I have a good pair of upper radiator mounts / braces for three core if that is what your needing. Bead blasted, primed and painted semi-gloss black. Good useable rubber cushions. No pics loaded right now. $15 to your door.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 11-05-2006, 12:08 AM   #3
stynchrr
stynchrr's Avatar
I only need one for the bottom. I just said top figuring that i could take it apart and use it on the bottom.
Old 11-05-2006, 06:38 AM   #4
junkyardjohn
junkyardjohn's Avatar
THE RUBBERS (ACTUALLY ALL RELATED PARTS) ARE AVAILABLE AFTERMARKET. THE RUBBERS ARE $5 EACH FROM MOST ANY VENDOR. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-06-2006, 01:16 PM   #5
stynchrr
stynchrr's Avatar
I have the rubbers I just need the metal part that rivits to the core support. Rust took care of the one that was there.
Old 11-09-2006, 07:05 PM   #6
uncle
Here's everything but the springs.
uncle is offline   Reply With Quote
Old 11-10-2006, 11:33 PM   #7
stynchrr
stynchrr's Avatar
thats great there are only a few things.
1. I don't need the pedal and bracket for the accelerator just the switch and wires
2. The Bracket for the brakes is wrong I need the long c channel going form the front of the brake booster to the bottom part of the fire wall but I do need a clip and pin that is on the piece shown. The pin attaches the rod that comes from the pedal to the linkage that is shown in your picture.
3. The pics below show the springs i need the left or top is the driver side showing the three broken or missing springs on the end of the seat. The other pic shows the passenger side with all springs there.
Sorry for the confusion. Let me know if I was clear enough this time. The rest of the stuff looks great.
Thanks Tim
Old 11-11-2006, 10:04 PM   #8
uncle
I'd rather not seperate the pedal assembly or the booster brackets, but I'll throw in the other booster bracket for the same price. I have the springs, just not out yet. Thanks Tim.
Old 11-11-2006, 10:51 PM   #9
stynchrr
stynchrr's Avatar
i understand not a problem. If the springs are what i need I am good to go I was just trying to reduce shipping weight. I am not sure if it would make a difference though.
Thanks Tim
Old 11-11-2006, 11:01 PM   #10
uncle
Maybe a pound or 2. I'll try to get the springs out soon.
Old 11-12-2006, 12:43 AM   #11
stynchrr
stynchrr's Avatar
Thank you don't let me jam you up I need the parts you have. Just let me know what you want to get them to my door and we will deal. I thank you for your time.
Good day
Old 11-20-2006, 02:29 PM   #12
stynchrr
stynchrr's Avatar
Any luck with those springs?
Old 11-20-2006, 04:40 PM   #13
uncle
All the core seats I had were bad on that side also.
Old 11-21-2006, 09:24 AM   #14
stynchrr
stynchrr's Avatar
Could you get some from the passenger side that i could make work?
Old 11-21-2006, 06:49 PM   #15
uncle
I don't think you can swap sides, but you might want to check.
Old 11-22-2006, 09:05 AM   #16
stynchrr
stynchrr's Avatar
Do you know of any place that has spring to repair this? if not would you mind pulling the three of the passenger side and a few longer ones from the middle? I am going to be away for the holiday so I might not be bya computer till sunday evening.
Old 11-22-2006, 04:20 PM   #17
uncle
I can do that.
Old 11-27-2006, 09:46 AM   #18
stynchrr
stynchrr's Avatar
That sounds great. Let me know what shipping is and how you would like to get paid I will get the $$ out to you.
O yeah my zip is 19934
