Old 11-11-2006, 11:47 AM   #1
QKENUF4U
QKENUF4U's Avatar
Question smaller diameter coil springs ???????
i just found the solution to my problem but i dont know if they make them or not.
do they make a small diameter coil spring for my 71 ? (rear/lowered)im not worried if i need to cut them down either since i dont use the truck to haul anything. if so who/how much ?
if they do then i can fit the 68 rear without a problem. thats the only real problem i have with this swap is my coils are a 1/4" from my tires now so i cant go narrower.
thanks
lance
QKENUF4U is offline   Reply With Quote
Old 11-11-2006, 12:33 PM   #2
QKENUF4U
QKENUF4U's Avatar
Re: smaller diameter coil springs ???????
found what im looking for. maybe i can still get this to work with a bit of money$$$ (6bolt to 5 bolt adapters and the skinny coils i found on the web)
Old 11-11-2006, 05:41 PM   #3
qksilver
Use coil over shocks........would completely remove the factory coils
qksilver is offline   Reply With Quote
Old 11-11-2006, 07:14 PM   #4
QKENUF4U
QKENUF4U's Avatar
Thumbs down Re: smaller diameter coil springs ???????
would love to but the cost is way more than the narrow coils i found and i would have to have mounts welded onto frame/rear etc. just adding more cost. guess thats the whole reason i said i would never do this again but here i am (had 8yrs in a 68 camaro and still never finished it)
Old 11-11-2006, 10:52 PM   #5
mikeoj
What are the smaller coils from?
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 11-12-2006, 12:52 AM   #6
QKENUF4U
QKENUF4U's Avatar
if these are the actual pics of the coils then here........
http://store.gaugemagazine.com/index...OD&ProdID=2499
Old 11-12-2006, 03:36 AM   #7
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I tried a set of "A" body springs and it only lowered the rear of my '67 stepside about 1". I then tried just the coil over Monroes that were on the truck and they were about the same at 1". I finally just put in some bags...now I want to notch it! Message? You can never get too low...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 11-12-2006, 06:25 AM   #8
Jim_PA
Arent' these just 3" drop springs?
Jim_PA is offline   Reply With Quote
Old 11-12-2006, 11:42 AM   #9
QKENUF4U
QKENUF4U's Avatar
Cool Re: smaller diameter coil springs ???????
my truck is lowered so thats what i need but the overall diameter is my biggest problem with this rear swap (other than he may actually have a 6 bolt rear ) i have enough room for the narrower rear if my springs where small around.
