Old 11-12-2006, 10:34 PM   #1
myersjeremy
myersjeremy's Avatar
Sensor beside oil pressure sensor?
Pulled the old 350 out of my truck and noticed at the back that there are two sensors. I know for certain that one of them is for the oil pressure gauge but I havent a clue what the other is for. They are teed in together and screw into the block with a single fitting into the oil pressure hole. It has factory wiring hooked to both so I think this is a factory deal. Wondering if i can do away with one of them??????? Thanks!!!!
Jeremy
myersjeremy is offline   Reply With Quote
Old 11-13-2006, 08:51 AM   #2
beaterC10
Re: Sensor beside oil pressure sensor?
Do you have gauges or idiot lights on the dash? If you have gauges I would say one sensor is for the gauges and the other is a switch for the electric choke. The switch is used to activate the choke when you have oil pressure.
beaterC10 is offline   Reply With Quote
Old 11-13-2006, 01:50 PM   #3
myersjeremy
Yes it does have an oil pressure gauge with the idiot light. I can do away with the choke sensor if i am going to an aftermarket carburetor right????
Jeremy
