Adjustable Tracking Bar
What is the best way to set the adjustable tracking bar to know that it is correct?
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
![]() Join Date: Sep 2001
What? You mean an adustable panhard bar? I don't get what you're asking.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
Progress = 0%
With the panhard bar adjusted correctly, the axle/wheels/tires should be centered left to right.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
the best way is once you install the bar, leave the "jam nut" loose and lower the truck so the weight is back on the rear tires. Then measure from back of tire/wheel to frame rails....adjust the heim joint until the measurements are the same..then snug up the jam nut.
ALSO YOU PANHARD ROD SHOULD BE AS LEVEL AS POSSIBLE. THE MORE ANGLE IT IS AT THE MORE IT WILL BID YOUR SUSPENSION.
Jim Davisburg, MI 69 Camaro SS LT-1/6-spd 71 C-20custom deluxe burb 402/400 (gonna get back to it) 72 C-10base burb 350/3-spd 79-VW Scirocco GT-3 race car 2.0L/5-spd 02 chevy suburban LT Supercharged dropped on 22's |
