11-14-2006, 01:16 AM | #1 |
Brakes on 72 Chevy truck
I was weondering has anyone ever put all wheel disk brakes on one of these? also i cant evn fo somereason get any fluid to my rear brakes any ides?
11-14-2006, 01:24 AM | #2 |
Location: vacaville ca, because it as far from indy as i can be
Re: Brakes on 72 Chevy truck
push the little black button on the proportioning vavle and just keep pumping, leave the bleeders open and go to town.
11-14-2006, 03:19 AM | #3 |
is that the same for a 71 and do you have a way of showing where that is at with a pic?
1971 Chevy C-10 . |
11-14-2006, 05:47 AM | #4 |
Designated A-hole!
If you're gonna use disc brakes on back you need a different proportioning valve/master cylinder anyways.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-14-2006, 10:46 AM | #5 |
chevy truck fan
i used the classic perform products rear disk brake kit for my '72. the kit was pretty easy to install, although the directions were a little bit confusing. agree with above if you do the change you will need to change your firewall brake setup as well. i changed to a '92 sub. booster & mc. i then put on the cpp 4 wheel disk prop. valve.
good luck!!! rodstored-72 |
