Tips on centering rear end?
Any good tips on centering the rear diff? I have installed a set of 3" drop springs and will probably get a set of 2" blocks to finish it off. With that much drop I'll need to get an adjustable panhard bar as well. And I'll need to get it all lined up correctly so as not to tear up my carrier bearing... Which may be part of my issue now with a new vibration. Also how much of a pinon shim will I need with a total of 5" of drop? Any help appreciated!
donovan
78 C10 LWB Super Cheyenne |
Re: Tips on centering rear end?
On centering the rear end; With the weight on the tires, measure from the frame rail to the brake backing plate, in the same place on each side. Then use a ratchet strap attached to the rear end & frame to pull it over until distance on each side is equal. Adjust panhard bar, and install.
I did plagerize this from another thread. But I did mine this way and it worked fine. So credit goes to the original author, whoever they are. I dunno about the pinion angle. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
Thanks for the info...
#4 | |||
Union Electrician
I just did mine the same way,3" springs and 2" blocks, no pinion angle isuses with a 5" drop the way we did it(or at all with 5", 6" and up will need some help)
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Out of the carpool lane.
I measured mine the same way but just pulled the body over and hooked in the adjustable sway bar once I had it set correctly.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
