![]() Join Date: Jul 2000
Flexplate Bolts
I am installing a flexplate on new engine using ARP bolts. I notice there is a slight amount of clearance between the holes and bolts and you can rotate the flex plate a fraction of an inch back and forth with the bolts only finger tight. Is this clearance normal?
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
Fabricate till you "puke"
yes, this is normal as the holes in the flexplate are slightly larger than the bolts
