Old 11-16-2006, 05:52 AM   #1
79underconstruction
79underconstruction's Avatar
2wd lift?
hey guys uhh i was wondering does anyone know where i can find some coil springs for the front end of my truck so i can lift the front so the turkc sits level. and does anyone know how big of tires i could put under a 79 scottsdale 2wd? it has 31 on it right now but im lookin to fit 35 mudders under it would i have to do a lift of anysort to fit those?
79underconstruction is offline   Reply With Quote
Old 11-16-2006, 08:41 AM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: 2wd lift?
Aim Industries 1-800-289-9980
try these folks.........I know they are the best price on lowering springs...they might have what u need
72freak is offline   Reply With Quote
Old 11-16-2006, 10:05 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: 2wd lift?
When I was running heavy duty springs on my truck, purchased from my local auto parts store, it sat level. I have posted the part number here in several similar threads over the years. You can probably find it if you do a search.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-16-2006, 11:26 AM   #4
84 400
Sb 400 club
84 400's Avatar
Re: 2wd lift?
there is an old thread about it. some guy was selling them on ebay i think. for 35's i think your gonna have to lift the back and front. good luck
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-16-2006, 11:33 AM   #5
krue
Designated A-hole!
krue's Avatar
Re: 2wd lift?
33's fit under my stock 70 2wd, but they rubbed when I turned the wheel sharply.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-16-2006, 02:25 PM   #6
79underconstruction
Re: 2wd lift?
hmm so then for me to fit 33's id prolly have to do a lil body lift or something fo rit not to rub? or does it rub on the corer of the inside the wheel wells? cuz i can cut the wheel wells a hair to it isnt noticeable... so i have some springs off a 88 blazer and i was wondering those springs r longer than mine think i could jus throw thos eunder my truck and it would lift the front end enough?
Old 11-16-2006, 07:15 PM   #7
EricS76
EricS76's Avatar
Re: 2wd lift?
I'd say you'd probably have to do a body lift or some fender trimming in the front and rear for 33's not to rub. I bought some 2 inch lift coils off e-bay about two years ago. I'm running 31's, and i have almost 7 inches from the top of the tire to the wheel well, but only 3.5 at the front and rear of the well. The most lift you're going to get from coil springs is about 2 inches. That's about all the suspension will give. I put mine in and the suspension sets pretty much at full droop. It rides like a tank too.
‘66 Chevy C-10, long bed fleetside, 350, 3 on the tree, 4-7 drop.
'77 chevy C-10 Custom Deluxe, 350, SM465 4 speed, flatbed.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
EricS76 is offline   Reply With Quote
Old 11-16-2006, 07:55 PM   #8
Prerunner1982
Prerunner1982's Avatar
Re: 2wd lift?
HERE I COME TO SAVE THE DAY!!!
At anyrate, here is the usual response I give to these questions.. if that doesn't answer your questions.. ask away. Not that I know everything, but if I dont someone here most likely will. Great group of knowledgeable people.
Coils will lift your truck but you will wear ball joints and tie rods faster as it puts them at an steeper angle.. also you will have little to NO droop in the suspension..
body lifts are ok, but have alot of problems associated.. adjust your steering, electrical connections, lift bumpers... etc... i prefer to stay away from body lifts...
there are advertised lifts, but they are just coils, Fabtechs kit is coils and possibly tubular control arms.. (if the ball joint mounting area is degreed then they wont wear as much)... However.. NOBODY currently sells a lift spindle, which would be the best way to go to keep proper geometery.. AIM ( )use to sell them, but quit due to little interest..
with some work you could swap ball joints (and/or control arms, i am not sure what is involved with this as i havent gotten that far yet) you could use 88-98 lift spindles...
As far as 35" tires, you could probably get away with using 2" lift coils and a 3" body lift. Only way to get that much lift with these trucks. At this point I would rather run fiberglass fenders or the next step to have a fully custom front suspension made with coil overs. Good luck and post up pics when you finish the lift..
I ran HD coils on the front and stocks springs on the back of my 82 and ran 32" tires with only minor rubbing at the very top fender lip that I rolled and then some on the inner fender but since its smooth I wasnt too worried. 33"s should fit fine in the back without trimming. With 32"s I had less than 2 fingers width between the tire and lower fender at its closest point....this was at a dead stop so this doesnt account for movement, but like I said, I rubbed at the very top of the fenders.. not at the lower edges.. 33"s would probably rub at both.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 11-16-2006, 08:15 PM   #9
Prerunner1982
Re: 2wd lift?
The parking lot is slopped, but the truck sits level front to rear.
Jon
Oklahoma Roll Call
Old 11-17-2006, 08:31 PM   #10
79underconstruction
Re: 2wd lift?
ok man thanks for the help guys.
