Old 10-15-2002, 02:08 PM   #1
Jmac05
L.E.D. Tail lights, Baby!
Jmac05's Avatar
Which Cylinder Heads to get
I might need to get new Cylinder heads soon. I have a 327, and I am going to be driving it every day, alot on the freeway. I'd like to get a 1405, or 1406 Edl. Carb, and the intake.
Prov 3:5-8
"Hook 'em"
L.E.D. Taillights for sale NOW!!!
If interested, visit:
www.earlyclassic.com
or our website:
www.jmcled.com
All 67-72 GM Taillights are on sale untill 5 p.m. on Dec
15th, with Guaranteed Christmas delivery!
joel.mcwaters@jmcled.com
Jmac05 is offline   Reply With Quote
Old 10-15-2002, 02:30 PM   #2
Mudder
Mudder's Avatar
Just did this!
I ordered a new set or vortecs yesterday w/roller rockers/ and Edlbrock air gap intake, but I got the Holley Avenger off road carb. I have a edlbrock performer intake and carter carb little over a year old for sale on the parts board. Looks like the vortecs will out flow most of the higher priced heads.
Mudder is offline   Reply With Quote
Old 10-15-2002, 02:40 PM   #3
racedvl
racedvl's Avatar
Thumbs up
Ditto on what Mudder said! Vortech heads. And you will have $$$ leftover for your intake and carb!
racedvl is offline   Reply With Quote
Old 10-15-2002, 03:06 PM   #4
70c10
67-72 Addict!
70c10's Avatar
How much for Vortecs?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-15-2002, 04:00 PM   #5
MikeB
MikeB's Avatar
Remember that they require a Performer Vortec manifold and center bolt valve covers. They cost prox $450/pair from places like Scoggin-Dickey Chevrolet at www.sdpc2000.com
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-15-2002, 04:07 PM   #6
Jmac05
Jmac05's Avatar
>>>>Remember that they require a Performer Vortec manifold and center bolt valve covers. They cost prox >>>>>$450/pair from places like Scoggin-Dickey Chevrolet at www.sdpc2000.com
So Can I use the edl. Carb? What intake should I get?
Prov 3:5-8
"Hook 'em"
or our website:
www.jmcled.com
Old 10-15-2002, 04:17 PM   #7
MikeB
MikeB's Avatar
You can use any carb. Manifold is Edelbrock Performer Vortec #2116 for idle-5500 rpm. Performer RPM Vortec #7116 is for bigger carb, cam, lower gears, and higher rpm with a sacrifice in low speed torque. www.edelbrock.com
Mike
Old 10-15-2002, 04:49 PM   #8
nate68
dart iron eagles are just a hair more than vortecs and regular sb intake manifolds are cheaper, centerbolt valve covers are way more money than regular sb, guideplates won't fit under stock vortec valve covers or at least mine wont
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 10-15-2002, 06:12 PM   #9
Project1970
14.1 @ 96MPH
Project1970's Avatar
One other thing to note is that Vortec heads have a 64cc combustion chamber; going from the stock heads on my truck to Vortecs got me a bump in compression to 10.0:1 with thick head gaskets. So I've got to burn premium now...however, whenever I get around to rebuilding the bottom end, I'll probably both go with a 383 setup and dished pistons to bring the compression back down.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 10-31-2002, 01:39 PM   #10
Jmac05
Jmac05's Avatar
Ok,
I have a 327. I'd like to know which p/n to get as far as the heads go. Should I get new cam, rockers, etc... I don't want to go crazy, this is a daily driver that I put about 100 miles on per day. SO gas mileage is a big factor!
P.S. LED taillights availible VERY soon (within 2-3 weeks)
Prov 3:5-8
"Hook 'em"
or our website:
www.jmcled.com
Old 10-31-2002, 04:31 PM   #11
bigjimzlll
bigjimzlll's Avatar
the last 3 digits on the heads are either 906 or 062...these are for the vortecs and since your looking for gas mileage and not big performance these would work well for you...you will end up spending over 700.00 for everything you need to do the swap. they are a nice mild performance upgrade..I myself do not like votecs(but im old) just like im not fond of the ls1 or sb2 motors..I like the old style sbc's...I like to interchange any manifold I want and the same with valve covers and rockers....etc..youir 327 probably has either 520 heads which are 60cc or camel humps which are 64cc...if your heads are the 520s you will lose a little C/R..good luck..get new head bolts and seal the threads with some arp sealant or equivilant
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-31-2002, 07:03 PM   #12
Mudder
Mudder's Avatar
I bought
the head kit from SD and it came with all the gaskets intake bolts and head bolts. Everything you need to do the swap except for the carb and gasket. Those guys there at Scoggin Dickey were very helpful too.
