Old 11-20-2006, 12:44 AM   #1
70ChevyChris
70ChevyChris's Avatar
drive shaft chnge?
I want to do a 4in lift and a friend told me I will need a new, longer, driveshaft. Then I priced a lift kit this weekend and was told that the transfer case can be dropped with brackets so that the driveshaft isn't needed. Can someone tell me the best route to take? Will dropping the transfer case cause clearance issues or linkage issues?
70ChevyChris is offline   Reply With Quote
Old 11-20-2006, 10:08 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Re: drive shaft chnge?
You should not need any shaft modification with a 4 inch lift.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 11-20-2006, 10:22 PM   #3
Bad71chev406sbc
Bad71chev406sbc's Avatar
When you go 6" of bigger, You'll need a long shaft. 4" kit, you're alrighty. I know this because Ive lifted a friends '69 4" and had no problems with stock shaft.
'71 SNB, 406sbc, TH350 w/ Transpak & Starshifter, 12bolt w/ 3.73s, 2" Early Classic front coils, 2.5" Flowmaster Super 40's
Bad71chev406sbc is offline   Reply With Quote
Old 11-20-2006, 11:31 PM   #4
1969k10stepside
My 69 is lifted 6 inches and it needs a new drivshaft that is longer.My 79 has a 4 inch lift and had no modification to the driveshafts or T case.Here is a pic of the 69 w/ a 6 inch lift for reference,its not pretty but it works.
Attachment 226238
1969k10stepside is offline   Reply With Quote
Old 11-21-2006, 08:50 PM   #5
qksilver
Replace the ujoints though, no need to get a longer drive shaft
qksilver is offline   Reply With Quote
Old 11-21-2006, 09:30 PM   #6
1969k10stepside
Change the u joints if you havent already
Old 11-21-2006, 11:20 PM   #7
Yukon Jack
Yukon Jack's Avatar
My 69 K20 with the Rockwell t/c did require driveshaft mods to work when I did the initial 4" lift. I initially had the front driveshaft lengthened then found it needed a CV.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
