Old 11-01-2006, 12:08 AM   #1
BIG CTY
Between the earth and the sky
BIG CTY's Avatar
I'm new here, and I need some help! You see...
...everytime I do something to my rustbucket I seem to mess something else up. But before I get into that, here is the post I put on the "Welcome" forum introducing myself. Now back to the issues
First, I put a new steering wheel on my bucket. I tightened it down too far, but I finally got it right - with one issue...the horn ALWAYS blows. So I disconnected it and straight wired a horn. Now my battery is dying. (My signal lights no longer cancel either, but I guess I have to live with that) Could it be that there is current being drawn from inside that d@mn steering wheel somewhere?
Also, I put in a brand new used bench seat from the junkyard in my bucket. After installing, the gas gauge stopped working. When I turn the key, it goes all the way past the "F." What in the he!! could that be? What should I check?
I'm sure there is more, but I'll stick to that for right now.... Help HELP!! Thanks in advance!
Chris - 1966 C10 Shortbed Fleetside, 1991 GMC Sierra 1500 Extended Cab, 1993 Blazer Sport 4x4
My other rides:
1969 Chevrolet Impala SS427 Convertible
1976 Dodge Tradesman B200
2002 Nissan Maxima 6 speed
2004 Mercedes Benz CL500
BIG CTY is offline   Reply With Quote
Old 11-01-2006, 12:24 AM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: I'm new here, and I need some help! You see...
First of all Welcome to the board.
1. Did you put the canceling cam (round plastic piece with a couple little legs on it) back in and in the right direction?
2. If the wire for the horn is still in the column and touching metal that will definatey cause a drain.
3.When you put the new seat in you could have unplugged the wire to the sending unit on the tank.
Good luck and post your problems, you will get good advice from people on this sight.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 11-01-2006, 11:55 AM   #3
GR82BME
GR82BME's Avatar
Something else you might want to check is when you bolted down your seat if you dident smash the fuel wire down when tightening up your seat...
GR82BME is offline   Reply With Quote
Old 11-23-2006, 04:42 PM   #4
FishSteelhead
FishSteelhead's Avatar
Had basically th same problem ie., battery drainin' because of wire touchin' metal after removal of steering wheel. As far as the gas gauge, check wirin' on tank, could have pulled it loose or cut into wires while yankin' seat out...
"There's no head like Steelhead"...
FishSteelhead is offline   Reply With Quote
Old 11-23-2006, 09:45 PM   #5
larry may
the fuel gage wire should run under the driver side door threshold molding. most are under the mat or carpet. Could have as mentioned earlier in this thread. the wire could be pinched. it is tan in color.......my.02%
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
