11-23-2006, 10:56 PM | #1 |
Tire Change Tool Kit Pictures?
I appear to be missing the jack and tool kit for my 72 C10. Just wanted to know what it looked like and where it went. I am guessing behind the pass side of the bench seat? There is a spring looking thing back behind the seat.
Thanks |
11-23-2006, 11:27 PM | #2 |
Re: Tire Change Tool Kit Pictures?
I jsut got the assembly manual. If i can get my scanner working I can scan a pix for you tomorrow. My girl friend tried to..........use it
11-23-2006, 11:47 PM | #3 |
A recent thread... http://67-72chevytrucks.com/vboard/s...highlight=jack
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
11-24-2006, 07:52 PM | #4 |
I think I will order one of those factory assembly manuals soon.
I saw those pictures recently, wasn't sure if a 70 model was the same as a 72. So the 67-72 must use the same hardware and kit then? Maybe pictures of a properly insalled tire change kit then... Thanks, Guys |
