11-25-2006, 07:30 PM | #1 |
NOT REALLY BANNED!
What the Frame?
Was under my truck today, after doing the brakes, noticed that my frame stops 18-20" then has two pieces of tube steel bolted to both original rails, then to the bumper brackets. Whats up with this? Should all LWB frames be like this? The tube steel looks like it's been added and the frame rails in the rear look factory.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
11-25-2006, 10:02 PM | #2 |
The Older Generation
Re: What the Frame?
Pictures??? Frame stops 18-20" from what? If I have the mental picture right it sounds like someboby modified it. The frame should be basically the same all the way front to back.... LockDoc
11-25-2006, 10:14 PM | #3 |
Re: What the Frame?
Here is a pic of the back of my frame:
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
11-25-2006, 10:47 PM | #4 |
'69 Step
Re: What the Frame?
Where did you get the red bump stops? Mine disappeared LONG ago.
11-26-2006, 02:08 AM | #5 |
Re: What the Frame?
I am curious about that sway bar. It looks like it mounts different than any others i have seen. And looks to be for the better. Got any more pics?
Jason |
11-26-2006, 02:18 AM | #6 |
A guy with a truck
Re: What the Frame?
1BadSS- sounds like someone lengthened your frame for some reason. Maybe wrecked in the rear at some point and repaired with box tubing. Just a guess...
Larry, you had to know this would happen... Check this link for the Camaro swaybar:linky
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-26-2006, 08:19 AM | #7 |
The LuvShack Garage
Re: What the Frame?
X2 I wanna know also, dimensions of them (Thickness) also Please
11-26-2006, 10:29 AM | #8 |
Re: What the Frame?
Another link to sway bar install:
http://67-72chevytrucks.com/vboard/s...hlight=swaybar The bump stops are energy suspension 3.9103.
