Old 11-26-2006, 05:15 PM   #1
skokie
skokie's Avatar
Throttle sticking
I took the 68 for a drive and I noticed that the throttle is sticking. I checked the gas pedal hinge on the firewall and that is not binding up. I checked on the throttle linkage (not sure if that is its name see pic piece is colored in green) and without the throttle rod or springs it is sticking. I sprayed some carb cleaner in there but no luck. Any suggestions?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-26-2006, 05:33 PM   #2
cdowns
cdowns's Avatar
Re: Throttle sticking
maybe lubrication??? if it moves if it pivots lube it // a pretty simple principal
Old 11-26-2006, 06:01 PM   #3
skokie
skokie's Avatar
What should I use to lubricate it? Also maybe hit it with some carb cleaner?
68 build thread
Old 11-26-2006, 06:18 PM   #4
cdowns
cdowns's Avatar
hit with carb cleaner to clean first then either a silicone lube or i like white lithium grease in the spray// also in the cab where the pedal likage pivots and goes thru firewall
Old 11-26-2006, 07:03 PM   #5
Boog
laying low
Boog's Avatar
You say "without the throttle rod or springs it is sticking" so the sticking is narrowed down to the carb and not the throttle rod. Make sure the primary pump lever is not touching the air cleaner. I have had that happen. It will stick. Remove the air cleaner and work the throttle without the linkage or spring hooked up and see how it works. If it still sticks you may need to remove the carb and inspect the base gasket and manifold for contact. With carb removed work the throttle. Does it still stick?
Is this a reman'd carb?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-27-2006, 01:44 AM   #6
skokie
skokie's Avatar
Well I disconnected the carb springs and throttle rod. With the carb still on the intake I gave it the throttle linkage (area in green) a good cleaning with carb cleaner. When I hooked up the throttle rod I noticed a slight catch. I extended the rod by 1 turn and it looks like that has fixed it.
68 build thread
