How hard is it to change a water pump on a 99 Tahoe?
My water pump needs to be changed as it is leaking and making noise. Is this something I should do myself or have someone else do? If I should do it myself, does anyone have any tips? thanks
paper or plastic?
Re: How hard is it to change a water pump on a 99 Tahoe?
If it has the 5.7 its real easy. What motor is it??
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
It's the 5.7
Big Block
Does it have the original radiator hoses and water pump bypass hoses? Now might be a good time to change them. The bottom radiator hose clamp is a little tricky. Its pretty tight down there.
Seperating the fan from the pump can be a pain allso, I used a oil filter strap wrench to hold the pulley and then broke the nut loose.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
402 BIG BLOCK
They do make a fan clutch tool that can be rented that makes it a lot easier to take the clutch off. After you get the clutch off its a breeze.
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala |
