Old 10-31-2002, 12:52 PM   #1
72ChevyCheyenne
72ChevyCheyenne's Avatar
Progress: Rolling Chassis
Front View
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 10-31-2002, 12:53 PM   #2
72ChevyCheyenne
Front Suspension
Bill Durham
72 Cheyenne
Old 10-31-2002, 12:54 PM   #3
72ChevyCheyenne
Rear end
Bill Durham
72 Cheyenne
Old 10-31-2002, 12:55 PM   #4
72ChevyCheyenne
Another rear end
Bill Durham
72 Cheyenne
Old 10-31-2002, 01:21 PM   #5
dubie
dubie's Avatar
Great pics, it looks like you're making some nice progress there!!
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 10-31-2002, 01:30 PM   #6
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Woah! You are getting way ahead of me there 72Cheyenne! It is looking good. How did that InLine brake line kit go on?
Did you sandblast everything before having it pcoated?
Keep up the good work. You will be a great resource for me as you will have lived it before I have to figure it out.
I'm hoping to get my posi ordered next week. I'm still a ways out to be able to sit back on her feet.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-31-2002, 01:34 PM   #7
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Looks great!. Can mufflers be powdercoated and withstand extreme heat?. That would look cool!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-31-2002, 02:25 PM   #8
72ChevyCheyenne
The inline Tube brake and fuel lines are great. Once I figured out which line went where, they fit like a glove.
The frame, crossmembers, upper/lower control arms sway bar and rear shock mounts were blasted and powder coated.
Bill Durham
72 Cheyenne
Old 10-31-2002, 09:28 PM   #9
jhow66
jhow66's Avatar
Is that the motor you are going to use under your name? If so send it to me and I will break it in for you in my other truck. This way when you are ready to start it up it will be ready to rock and roll. (which they will as I have a 502HO in my 71 Cheyenne)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 10-31-2002, 09:30 PM   #10
flyin99
creator of kong
flyin99's Avatar
smoooooooooth !!!!!!!!!!!!
flyin99 is offline   Reply With Quote
Old 10-31-2002, 09:35 PM   #11
jhow66
jhow66's Avatar
P.S. Hedmen makes a set of 2"X3" headers that fit like a glove.
Old 10-31-2002, 11:08 PM   #12
firstgencamaros
Very nice. I wish I had the room to do that with mine. My garage is full of first generation camaros...... I guess I shouldn't really complain huh? Oh well... looks good. Keep us posted on the progress.
Later,
FGC
firstgencamaros is offline   Reply With Quote
Old 10-31-2002, 11:16 PM   #13
BIG ORANGE
BIG ORANGE's Avatar
Question Little info.
Hey that looks good ,I be glad when I catch up to were you are.
Did you sandblast the frame then prime and paint or what?
What kind of suspention bushing's did you use?
Were the brake and gas line's high?
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 11-01-2002, 06:48 AM   #14
72ChevyCheyenne
Jhow66 - The ZZ502 came yesterday and I am going to pick up some Hooker super comps today. Which towers and moter mounts did you use in your 71?
Big Orange - I had the frame blasted and powder coated. The suspension bushings are all rubber except for the front sway bar, rear trailing arms and the adjustable panhard bar, those are poly. Since I went with stainless, they were around $500 for the brake, tranny and custom fuel lines.
Bill Durham
72 Cheyenne
Old 11-01-2002, 11:44 AM   #15
jhow66
jhow66's Avatar
Mine was a factory 402 so these brackets and mounts will work in yours. What gear are you pulling? I have a 3.07 and still had to put in a Eaton Posi to be able to use the TQ of this motors. Hope yours does not use oil like mine-( 1 qt. per 400 miles since new- 5000+ miles now) but does not smoke a lick anytime. Still would buy another though. Enjoy!
Old 11-01-2002, 12:25 PM   #16
72ChevyCheyenne
I am running a 3.42 gear with a new Eaton Posi. The General tod me that they had changed the oil ring to a different type in the later 502s. How long have you had yours?
Bill Durham
72 Cheyenne
Old 11-01-2002, 12:39 PM   #17
Randy70C-10
Randy70C-10's Avatar
Re: Little info.
We've seen your Suburban. We'll be glad to catch up where "you" are.
Randy70C-10 is offline   Reply With Quote
Old 11-01-2002, 08:36 PM   #18
jhow66
jhow66's Avatar
rings
I got mine in August of 2000. Did they say what ring to use?When I tried to contact the "General" they said to check with your dealer. Dealer said "duh". so I gave up and living with it. How long til it will be finished? Need pictures when done.
Old 11-02-2002, 07:04 AM   #19
72ChevyCheyenne
No they didn't say which ring it was. I plan on having it done by Xmas. What tranny are you running?
Bill Durham
72 Cheyenne
Old 11-02-2002, 01:34 PM   #20
jhow66
jhow66's Avatar
400 Turbo (here's my other "toy")
Old 11-04-2002, 02:40 AM   #21
lugnuts
Hey there 72chevycheyenne where did you get the gas tank and how hard was it to mount? I have a 72 short stepside with the gas tank in the cab and I want to move it, good looking job you got goin there.
lugnuts is offline   Reply With Quote
Old 11-04-2002, 06:30 AM   #22
72ChevyCheyenne
I got it out of a local junk yard and had it steamed and sealed. It was pretty easy to mount the way I did it. Instead of using the straps, I drilled 3/8" holes in the flanges on the side of the tank. I then bolted it to the frame using the existing frame holes and sway bar link bolts with the rubber bushings to allow for the frame to flex without stressing the seam on the tank itself.
Bill Durham
72 Cheyenne
Old 11-04-2002, 08:26 AM   #23
69 Short Fleet
Thumbs up
Hi 72chevycheyenne: Exellent job on your truck, looking forward to more picks, Hi 70c10 Ive got a KZ 1000 show bike as well and got the header ceramic coated (same proceedure as powder coating) colours are somewhat limited but it came out really nice, the only bad feedback Ive heard so far is the coating can sometimes turn a lighter colour (primarily closer to the head). Take care, Doug (new to board)
69 Short Fleet is offline   Reply With Quote
Old 11-04-2002, 08:30 AM   #24
DarkFox1
in WAY over my head
DarkFox1's Avatar
lookin good! I'm right behind you.. about $1400+ behind you lol
DarkFox1 is offline   Reply With Quote
