![]() Join Date: Oct 2001
Help me drop that 71 in the rear!
I've had 70 ,67 to 72 chevy's trucks,blazer's and burb's in a 12 yr period but I have never tried to drop a leafspring truck. What is the easiest and cheapest way to drop this truck say 3 inches in the rear? The springs are on top of the rearend, I got the front under control just have never drop a leafspring truck, could some one give me alittle
HELP! thanks in advance..........
Things happen for a reason! |
Chevy Truck Addict
![]() Join Date: Aug 2006
Re: Help me drop that 71 in the rear!
If you only want a 3 inch drop, I'd say you have a few options:
1. Cheapest. Take a spring or 2 out and put in a drop shackle (drop shackle from Early Classic - $59). 2. Same as above but have your springs de-arched. Could be almost as cheap as option 1 depending on how well you get along with your friendly neighborhood spring shop owner. 3. 4" Drop rear leaf kit from Early Classic - $369. Could be combined with a shackle at some point to get as much as a 5-1/2" drop.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
Formerly LSC71
If you are still running the original leafs, dropping the short thick one might be all you need to do. I've seen trucks that have hit the bumpstops after removing the overload leaf.
One other thing to keep in mind, if you do end up taking leafs out, don't plan on towing or hauling much, there just won't be enough spring rate left to handle the extra weight. Last edited by craig@ridetech.com; 11-30-2006 at 10:02 AM. |
Chevy Truck Addict
I agree with LSC71's comment about removing leafs. The previous owner of my truck had removed a couple of leaves. After I flipped the axle to bring it down some more I was hitting bottom all the time. The rear end was so spongy I couldn't even haul my luggage on long trips without bottoming out all the time. I ended up adding a few leaves back in and having the spring re-arched to get the drop I was after.
If you can afford the expense, re-arching the springs or purchasing a drop spring is probably the way to go.
What if I flipped the spring where the rearend sets ontop of the spring instead spring setting ontop of the rearend?
have yall done this and does it work OK? I'm gonna sale the truck so i dont want to tie any more cash up into the truck but I think lowering it would help the sale of it because it set up high! thanks Big O.
#6 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
well if your just going to sell it i would start asking around and find some used shackels they will only give you 2 in but you shold be able to get some cheap and let whoever buys it worry about what they want to do when they get it
http://www.cardomain.com/ride/2461088 |
