12-02-2006, 10:52 PM | #1 |
New Member
drive shaft questions
guys im a former vw fan and now im building a 72 chevy truck,what i want to know is did all short bed chevys come with two peice drive shafts or did some of them come with one peice drive shafts. thamks for any help.
12-03-2006, 08:47 AM | #2 |
Re: drive shaft questions
short or long, they all had 2 piece shafts....
1997 GMC Sierra Ext 1965 Mustang |
12-03-2006, 09:10 AM | #3 |
WTB this ad
Sorry, but in my experience a swb that was originally a 6cyl straight shift would have a one piece driveshaft. Now, all of the swb v8 auto trucks I have seen have come with a two piece shaft.
12-03-2006, 12:28 PM | #4 |
Questionable
I believe see ten is correct.
my '68 C10 with 3spd (on tree) still has the stock 1pc driveshaft in it. hello and welcome to the forum from a fellow VW fan my truck, and my dub:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
12-03-2006, 12:34 PM | #5 |
My 71 K10(4x4) which had a 292 and a Sm465 4 speed had a one piece drive shaft while a swb w/ a 350/th350 had a 2 piece drive shaft.
12-03-2006, 02:17 PM | #6 |
OK.......now my question is, I'm repacing a six cyl. W/PG with a 350/TH350. Am I going to be able to use my one piece shaft?
Smitty
Stepsides look like real trucks! Smitty |
12-03-2006, 02:27 PM | #7 |
Dave's not here, man
I believe I remember reading somewhere that a short shaft 350 is the same as a Powerglide as far as length and that their driveshafts can be used interchangeably. Someone please correct me if I'm wrong.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 12-03-2006 at 02:28 PM. |
12-03-2006, 02:38 PM | #8 |
Fabricate till you "puke"
http://www.tciauto.com/Products/TechInfo/trans_dims.asp its close enough to drop in crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-03-2006, 03:46 PM | #9 |
its all about the +6 inches
as long as he places the engine in the inline location.
If the TH350 is the short shaft one, then a drive shaft of 4 foot 10 inches (from center of U-joint to center of U-joint) will do the truck on a coil rear SWB with the small block in the correct location and a short shaft TH350. |
12-03-2006, 05:07 PM | #10 | |
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 12-03-2006 at 05:08 PM. |
12-03-2006, 05:24 PM | #11 |
I've got a 67 Short stepside that was originally a six cylinder and three speed. My 350 and th350 dropped right in close enough to use the original one piece drive shaft.
12-03-2006, 08:40 PM | #12 |
My truck was originally a 6cyl 3 sped manual with 2 piece drive shaft.
I have a 350 vortec engine with a NV3500 tranny (tranny out of a99 model truck) and I was able to use my original shaft including the yoke. Engine is in the factory V-8 position.
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
12-03-2006, 08:54 PM | #13 |
all LWB trucks had the 2 pieve shaft.
12-04-2006, 12:57 AM | #14 |
Thanks for the help, guys! I had hoped to place the v-8 in the factory position, but it looks like that'll require a different shaft
