Old 12-02-2006, 12:24 AM   #1
Low68
Low68's Avatar
bag controls
How does every body control their bags? I really like the idea of the Air ride level pro, but don't have the 1000+ dollars for the electronics. I don't want to run air lines into the cab, so a remote sender is a must. Dakota Digital has some nice gauges, but they are expensive too. I figure I can make my own control panel, as I have already succesfully done that for my dad's truck. So I am just looking for what you guys are doing so I can get some ideas. Thanks.
Dan
Build Thread
Low68 is offline   Reply With Quote
Old 12-02-2006, 02:22 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: bag controls
I would recommend some of the Air Ride Tech. valves, some paddle switches, and gauges (if you want to get a little fancier use some Dakota Digital air pressure gauges and senders). This is a clean, functional set-up that won't run you too much.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-02-2006, 02:34 AM   #3
jimmydean
jimmydean's Avatar
Re: bag controls
This is what I ran:
I think I paid $30 for it. It's clean and was easy to hook up. The controls are 4"x2"x1", so it's not huge like some of the other setups. I've been real happy so far, but my truck is still in the driveway. I mounted the box under the driver seat and have the control in the split of my 60/40 bench.
As far as running air lines in the cab, it's only 4 1/8" hoses. Mine are in pairs (2 per side) and it's smaller than the wires I ran for the switches themselves.
<edit> the cable for the control box is about 5' long, so I can stand outside and control my truck. It's safer that way until I get the adjusters on my dump valves. Right now my truck dumps like it's going off a cliff.
jimmydean is offline   Reply With Quote
Old 12-02-2006, 10:25 AM   #4
Shane
Shane's Avatar
Re: bag controls
hey jimmydean ... where did you score the control unit for $30?
Shane is offline   Reply With Quote
Old 12-02-2006, 11:35 AM   #5
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: bag controls
most likely on ebay. I've seen them on there for that price.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 12-02-2006, 01:51 PM   #6
jimmydean
jimmydean's Avatar
Re: bag controls
Ebay. He had it listed for $39 (a good deal) "or best offer". I told him I would give him $30 shipped and he took it.
I would have paid $39 for it, but he asked for offers, so I offered.
My right side seems to fill faster than my left for some reason, so when I use the middle button, it comes up sideways. I should have my fill/dump adjusters early next week. I should have my rear done this weekend since I am working on it right now!
Old 12-02-2006, 02:50 PM   #7
XXL
Seņor Member
XXL's Avatar
Re: bag controls
Looks like quite a deal for $30!
The problem I have with the gauge lines isn't their size, but the fact that they're air lines... 4 years or so ago, when I was using ART dual needle gauges, I had a gauge air line break (they're very thin wall and flimsy-- not like the DOT lines for the bags themselves), and since it's reading bag pressure, that means it's LEAKING bag pressure. Fortunately, I had enough compressor and air tank to limp my way home by constantly pumping it up as it leaked out.
I currently don't have any gauges installed... been that way for some time. I do have a DD unit to install, but just haven't gotten to it. The senders are threaded directly into the ART valves, so there are no gauge lines to pop.
XXL is offline   Reply With Quote
Old 12-02-2006, 03:02 PM   #8
abadsvt
abadsvt's Avatar
Re: bag controls
I didn't know that you can do remote sensors instead of running air lines to the truck. Thats awesome. Is there any wrong with that or is it just more money? Sorry to hijack! thanks Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 12-02-2006, 03:20 PM   #9
XXL
Seņor Member
XXL's Avatar
Re: bag controls
Yep. Same as how most cars deal with oil pressure readings. They are converted from fluid pressure to an electrical signal via a transducer (we usually call them sending units), and a voltage signal is then sent to the electronic gauge that's calibrated for the voltage value coming out of the sender.
Old 12-02-2006, 03:35 PM   #10
LuckyHG
LuckyHG's Avatar
Re: bag controls
I really like the dakota digital ones, a friend of mine found a set up for $100, never used still in box. PErsonally i just run the 1/4 inch air line into the cab
71' 2wd sub <------parts donations accepted
99' 4wd big block sub
92' K2500 ext cab Lb
95' S-10 sfbd, hydro's, etc.
02' Ram bagged etc.
83' International School bus...flat black with alot of room
www.Homegrowncustoms.com
LuckyHG is offline   Reply With Quote
Old 12-02-2006, 04:08 PM   #11
robsm88
robsm88's Avatar
Re: bag controls
Question about this. Ok, my parts have been here for some time while I installed the 4-link and bags. I am setting up my air system now and noticed that I ordered 1/4 inch line and fittings for my guages. I noticed most peoples setups seem to be running 1/8". Anyone see any problem using 1/4 other than the bigger hole in the cab? Thanks.
robsm88 is offline   Reply With Quote
Old 12-02-2006, 06:36 PM   #12
XXL
Seņor Member
XXL's Avatar
Re: bag controls
Air pressure is air pressure, so you're fine so long as you adapt down to the fittings on the gauges.
Old 12-02-2006, 07:22 PM   #13
Shane
Shane's Avatar
Re: bag controls
How did you configure your search to find such an item? I did a search on "bag controls ... air bag control ... etc" and didn't see anything.
Thanks!
Old 12-02-2006, 08:55 PM   #14
jimmydean
jimmydean's Avatar
Re: bag controls
Thanks!
"7 switch air"
<edit> I forget what I did the first time, I think I did a search for "switch box" or something. He has had others too, but 7 switches is what I was looking for. I just noticed another seller has one (same exact setup) for $100 + $29 shipping, ouch.
Old 12-02-2006, 10:21 PM   #15
Shane
Shane's Avatar
Re: bag controls
Thanks jimmydean ... i sent him an email asking details.
Old 12-04-2006, 08:50 AM   #16
LuckyHG
LuckyHG's Avatar
Re: bag controls
Makes no difference, i have seen people run 1/2 all the way into the cab.
02' Ram bagged etc.
