Old 12-02-2006, 11:53 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
Make the bad noises go away! :whine:
I just rebuilt my transmission. Took me about a month to learn as I went! Finally put it back in the Blazer, filled up all the fluids, started it and immediatly heard a knocking noise. Thought it was the transmission All that work!!! Anyway, I slept on it and went out today to take a look at it. SOUNDS LIKE ITS THE MOTOR! The thing was sitting for about a month in my garage and ran fine when I parked it for the trans rebuild. Also, it looks like there is a fine mist of oil coming out of the passenger tail pipe, the same side as the sound (I think). It is a little deaper sounding that a lifter taping, so it has me a little worried thinking that its a pushrod or worse, connecting rod! Anyway, just thought I would share my grief.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-03-2006, 12:07 AM   #2
72CSTC5
72CSTC5's Avatar
Re: Make the bad noises go away! :whine:
Pull your plugs and check them to see if you have excessive blowby on one of the cylinders or after you run it for a bit shoot it with a digital thermometer to check cylinder temperature difference if one cylinder is dead or do a compression test on the motor. You can rent a tester I believe from an auto supply store.
72CSTC5 is offline   Reply With Quote
Old 12-03-2006, 09:43 AM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Man that really does suck, here's hoping for the best
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-03-2006, 12:15 PM   #4
bagged74
its just $$$$$
bagged74's Avatar
this may sound really stupid, but.....check and make sure the torque convertor bolts are tight. if they are loose it will make a terrible noise that sounds like the motor knocking. cracked flex plate also will make a similar noise.
bagged74 is offline   Reply With Quote
Old 12-03-2006, 07:18 PM   #5
RANDY COX
RANDY COX's Avatar
Bagged74,I was thinking the same thing,I use to have a 74 blazer 4x4 and the torque converter bolts had came loose and it knocked pretty good,so I would too check those bolts.hope this helps.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-03-2006, 07:56 PM   #6
krue
Designated A-hole!
krue's Avatar
Btdt on the t/c bolts.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-03-2006, 09:23 PM   #7
Jtrux
I'm a poor spectator
Jtrux's Avatar
I have a compression tester if you need to borrow it. I work til 4 during the week.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-03-2006, 11:18 PM   #8
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'll quadurple the note about the TC bolts,
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-04-2006, 11:44 AM   #9
bryanw1968
bryanw1968's Avatar
Good chance it's the TC bolts. I had a '66 that had a BAD knock because of that.
If that's not it, you could have some stickiness in the valve train since it's been sitting so long. Through some Marvel's Mystery Oil in it if tightening the TC bolts doesn't help.
Also, I've never seen loose TC bolts make oil come out of one side of the motor
bryanw1968 is offline   Reply With Quote
Old 12-04-2006, 12:39 PM   #10
Critter
Future TOTM Winner
Critter's Avatar
Yep, the oil spray from the tailpipe is what scares me. I didn't notice it doing it when I parked the thing. I was thinking though, it has been sitting for a while, maybe the oil was only from startup. Honestly, I really havn't had a chance to watch it real close. Same goes for the T/C bolts. I hope to look at it again tonight or tomorrow. Jtrux, I might be taking you up on your compression guage offer. Thanks for all the suggestions guys!
Old 12-08-2006, 11:55 AM   #11
Critter
Future TOTM Winner
Critter's Avatar
Ok, I made the bad noises go away myself. I am a little embarrassed to say this but…first of all the oil spray was just black water vapor. There is so much junk in my old exhaust, it is blowing out black crap everywhere. Second, the knocking was in the distributor area and was easily fixed. I guess the little “Un-tightening Demons” came in and worked their magic while I wasn’t looking. Anyway, in my own defense, last night was the first chance I have had to really get my hands dirty and figure out what was wrong. It was fixed in under an hour. Thanks for the help.
Old 12-08-2006, 07:27 PM   #12
Jtrux
Jtrux's Avatar
You sure are brave to admit that. Oh, and don't try to act like you fixed it all by yourself...without me you would of had to fetch the tools yourself.
Old 12-09-2006, 12:39 AM   #13
Critter
Future TOTM Winner
Critter's Avatar
Yeah, I figure we have to laugh at ourselves every now-and-then. I'm just happy it was nothing serious! And I appreciate the help, crawling up and down that grill can be a pain in the @ss. Your turn to make some progress.
