Old 05-03-2002, 12:45 AM   #1
AZ68
Post door hinges
Has anyone rebuilt thes and if so where did you get the parts and how is it done -----thanx in advance--- Bob
68 c-10 lwb to swb 383 lr stroker 700 r4 starting frame off now
phoenix, arizona
AZ68 is offline   Reply With Quote
Old 05-03-2002, 01:40 AM   #2
nroden
nroden's Avatar
Post
1.Well obviously you have to take off the door.
2.Beat the pin from the bottom... if it doesnt come off heat it up with a torch and then try
3.You will probably also wan't to replace the friction plate
4.You can buy the pin and bushings and friction from NAPA or local parts store probably.. the route I took was ordering a door hinge repair kit (pin and bushings) from www.gmcpauls.com and then getting the friction plate from local GM Dealer. LMC also sells all the parts but I DO NOT recommend LMC because of their junky service
Nick Rodenberg
Wellington, MO
http://nickrod.port5.com
You can click on "My 72 Chevy Truck"
I have a 72 Cheyenne 10 with a V8 350 and a TH-350 auto-tranny.
Ochre/White/Ochre
Runs well... working on body.
Plan to get painted weekend before memorial day weekend.
Planned to be done March 7 when I turned 16. Didn't happen. Chose to do better job and be behind schedule instead of 1/2 doing it and it looking like junk.
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
