12-07-2006, 02:04 PM | #1 |
Front Suspension ID Help
I have a new toy ,'68 stepside ,and want to lower it a little more than it is now. It has beend changed to 5 lug disc. How do I ID what suspension that they used? The young guy I got it from didn't know the history on it. I would like to put 2.5" drop spindleson the front but I don't know what year to buy.
12-07-2006, 02:29 PM | #2 |
Gone Fishing
Re: Front Suspension ID Help
Is it the rubber bushining type or the steel shaft type? The rubber bushing type is 73 and +
The steel shaft ones are 71-72
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
12-07-2006, 03:29 PM | #3 |
I'm sorry I'm not following you. Which part are you talking about?
12-07-2006, 03:34 PM | #4 |
Gone Fishing
The control arm/a-frame bushings
12-07-2006, 03:46 PM | #5 |
Do you mean the shaft at the end of the control arm. One of the p.o.s before me did the same thing to my 68. Didnt mean to hijack but inquiring minds like to know.
Certifiably crazy person |
12-07-2006, 04:46 PM | #6 |
Gone Fishing
Yes f it has a big nut with a grease fittin then it is the steel type shaft
12-07-2006, 05:05 PM | #7 |
Fabricate till you "puke"
If you look at the 71-72, vs the 73 + , the difference is in the taper on the upper balljoints, & the outer tierod ends. IMO, I would go 73-up on the drop spindles, as they are cheaper. the lower ball joints are the same 71-87, so you just need to watch the taper on the top hole & the outer tie rod hole & replace the pcs as needed. Best of luck.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 12-07-2006 at 05:06 PM. |
